Hifiman HE6-SE
Mar 9, 2021 at 3:26 PM Post #1,397 of 3,880
I would also be interested. Is it too much to ask for the STL file? If not understandable.
Sure, would've put in on my site sooner or later anyways
If you could find a way to produce these, I’d be interested in a set
Just pm me, or use the stl
  • he6se_grill_v3.zip
Mar 10, 2021 at 7:45 AM Post #1,400 of 3,880
I wish I can get a carbon fiber oem for it, like the one for Audeze. Anyone knows?
with some washers the audeze headband will go straight on.
https://www.reddit.com/r/headphones...ducing_the_audiman_lcd500_with_special_guest/
You can get all the yoke kit from any dealer you have a relationship with or straight from audeze support if you are an audeze owner.
https://bloomaudio.com/products/audeze-universal-yoke-replacement-kit example, hifi heaven used to sell them but they seem to have stopped in the last week, but any dealer can order the part (1079-KT) for you
Mar 10, 2021 at 3:21 PM Post #1,401 of 3,880
is the adorama deal over
For now, yes.
I came here to post that I noticed that the "special url" doesn't work any longer for the Hifiman HE6SE V2...
I was hoping there was another discount link, but apparently not.
I haven't tried the other Adorama product links that also had discounts with the "?emailprice=t" added:
https://www.adorama.com/hmhe6sev2.html?emailprice=t
"Low Stock - Limited Quantity Available"
Maybe Adorama will drop the price again when they get their next "boatload" of Hifiman HE6SE V2's :)
Mar 10, 2021 at 8:50 PM Post #1,402 of 3,880
Your best bet is probably to set a keyword alert like "Hifiman" on the Slickdeals website.
Mar 10, 2021 at 10:18 PM Post #1,403 of 3,880
Why even bother selling it for 1799. At least it tells you how much it really costs to produce a HE-6. Maybe $50 bucks per unit. I could understand black friday sale. You fall for 1799 and see multiple 699 deal throughout the year.
Mar 12, 2021 at 9:40 AM Post #1,405 of 3,880
are the carbon headbands larger than the he6se OG ?
Mar 12, 2021 at 10:03 AM Post #1,406 of 3,880
Tell me more about the workaround... ;] Just bought a 6 screw on someone's suggestion and would like to use the Audeze headband.
:raised_hand::slight_smile: Do you have a loicense for that?
Mar 12, 2021 at 10:14 AM Post #1,407 of 3,880
Sure! 😁
Mar 12, 2021 at 10:53 AM Post #1,408 of 3,880
You can use the extended audeze yoke rods if you want
it'll go straight onto all circular cup hifimans, you just need 3mm washers and some tin snips to cut off the small protrusion on one side.
Mar 12, 2021 at 11:05 AM Post #1,409 of 3,880
If you're a function over form kind of person, you can also create a really comfortable leather suspension strap for just the cost of some scrap leather and a couple minutes. If you split off the leather at the ends like I did, you need about 8 5/8" between the cuts for a comfortable fit at max headband extension.
Mar 12, 2021 at 11:07 AM Post #1,410 of 3,880
Audeze headband weighs less as well, that's worth the money to me
