Hifiman HE1000 Planar Dynamic Headphone
Feb 22, 2016 at 6:46 AM Post #7,261 of 14,626
Shame I could't get a comfortable fit with the Odin. And the adjustment mechanism is just dumb
False, once well set with the adjustment knobs "2 axis" (nb: also, don't hesitate to twist outwards, the metal headband, to have less lateral pressure), comfort is just as good (or bad, depending on perspective
), see even a little better than that of the LCD3 (thanks to its flexible leather headband  suspension).
See, also,  the many adjusting photos and testimony, on the thread Kennerton.
For examples :
http://www.head-fi.org/t/732814/new-kennerton-odin-planar-magnetic-magister-vali-headphones-cables-amps-from-fischer-at-ifa/345#post_12298506
http://www.head-fi.org/t/732814/new-kennerton-odin-planar-magnetic-magister-vali-headphones-cables-amps-from-fischer-at-ifa/345#post_12296054
http://www.head-fi.org/t/732814/new-kennerton-odin-planar-magnetic-magister-vali-headphones-cables-amps-from-fischer-at-ifa/405#post_12339555
Feb 22, 2016 at 1:06 PM Post #7,262 of 14,626
I bought a pair of he-1000 last week. I'm currently burning them in. I'm a bit worried about my set. Both drivers have what look like veins or wrinkles inside them. I'm not sure what this is. Is it normal? In this picture you can see them primarily on the left hand side.
Feb 22, 2016 at 2:07 PM Post #7,264 of 14,626
Yes, mine has them in both drivers. I consider it normal - no worries. The sound is clean and immaculate.
Feb 22, 2016 at 2:09 PM Post #7,265 of 14,626
There were similar posts in the HE400i thread. I also do not think it is a concern.
Feb 22, 2016 at 2:11 PM Post #7,266 of 14,626
send the pics to HiFiman and let us know what they say about it.
To me this is not normal!
In our (audiophile) world, minor differences in housing, material, geometry ...etc. affect sound freq
Feb 22, 2016 at 2:36 PM Post #7,267 of 14,626
It is tough to see what veins or wrinkles you are looking at from this detailed picture.
There is a thin pantyhose like nylon cover that helps to prevent dust from the drivers on top.  This layer have irregularities.  I have minor ones on mine as well.  If you look this close to other TOL headphones like LCD3, K812, HD800, SR009 or even Orphesus; you may see as well.  Some not so easy as the driver color may blend into the fabric on top.  If it is this that you are seeing, there is no effects on sound.
Now, if the veins or wrinkles are on the metal surfaces, you should send back for an exchange.
Just move the fabric a bit to see where the irregularities are.
Feb 22, 2016 at 3:20 PM Post #7,268 of 14,626
just took a look at mine and i see no such wrinkles...perhaps it is only cosmetic?
Feb 22, 2016 at 5:05 PM Post #7,269 of 14,626
That's what I'm wondering. I've sent email to ask the company
Feb 22, 2016 at 9:36 PM Post #7,272 of 14,626
I have maybe 50 hours on them so far. They sounded rough out of the gate but now they just keep getting better and better. They're quite a contrast to my LCD-X (which I love)
Feb 22, 2016 at 9:44 PM Post #7,273 of 14,626
I am currently considering the HE1000 as an upgrade to my LCD-X.
Do you mind making a comparison for me and do you think one is truly better than the other? Thanks.
Feb 22, 2016 at 11:27 PM Post #7,274 of 14,626
I'll post a comparison. It may be a while, though. They are supposed to need 140-150 hours to burn in. If I'd given an opinion a couple of days ago it would have been much different than today.
Feb 23, 2016 at 3:20 AM Post #7,275 of 14,626
Thank you kindly, I am very interested as I am currently looking to own these and the LCD-X.
