HifiMAN HE-6 Planar Magnetic Headphone
- Thread starter JIGF
rlawli
- Jan 30, 2011
I prefer my Threshold 400A, factory upgraded to e Series specs, with an LDR passive preamp between the 400A and source.
Skyhawk182
vlach
Here's what I ran my HE-6 off of................and now my HE-6SE - straight from the speaker taps. 250 wpc of vintage power.............
Love that power amp!
So how do you hook up the headphones...is there some kind of inline resistor between the headphones and speaker taps?
No resistors whatsoever. I once tried the HiFiMan resistor box a few years ago and clearly noticed the sound degradation compared to straight from the taps.
You get a speaker tap connector to XLR and plug the supplied HFM cable to it.
The Spec 1 preamp handles any issues with volume knob issues that would be prevalent (too touchy, etc.).
It's best to run directly off the taps on the Spec 2 since the HP out has 150 Ohms resistors for each channel
I found the service manual for Spec 1/2 system:
vlach
Interesting...maybe i should hook up my HE-500 directly to the speaker taps of my CR-2020...i think the headphone output has 120 ohm resistors. What do you think?
vlach
Can you recommend such a connector?
Yeah, just be careful with the volume.
Here's a pic of it. I got three of these made by Ted @ Headphone Lounge - outstanding service and quality.
That's really interesting. Good info..................It's best to run directly off the taps on the Spec 2 since the HP out has 150 Ohms resistors for each channel
vlach
Perfect, i will get myself one and find out for myself, thank you!
Mawrchi
Has anyone tried the He-6 through a Bryston 3B3? I have the amp for my speaker setup, but wondering if it's worth getting an adapter to try with these.
Why not just give it a try? Adapters are relatively cheap and I know some crazies who run HE-6 of 250W+ no problem. Just be careful with the volume and connect HE-6 to the adapter after everything is turned on and disconnect before powering down with no music playing.
