You can try a smooth solid state amp like the denon pma 1500ae. It's very liquid sound yet very precise.
HifiMAN HE-6 Planar Magnetic Headphone
- Thread starter JIGF
The
First Watt J2 is execellent with the HE-6. It will fit these requirements too.You can try a smooth solid state amp like the denon pma 1500ae. It's very liquid sound yet very precise.
Yeah but very expensive !
Textfeud
- Apr 28, 2012
Keithpgdrb
Sponsor: ZMF Headphones
- May 22, 2008
I have the same train of thought. I tried my he6 with my restored Fisher 500 C. Not a good combo. You would want to use the speaker taps. But then you have to use the adapter resistors to protect your headphones. This change the sound to much to me, not to my liking. The answer always is try it yourself. But that was my experience.What is the general consensus regarding a tube speaker amp? I kinda miss the glow of a tube amp sometimes. I really love the Yamaha CA-1000 & Hifiman HE-6 combination though. Really can't complain, but maybe a good tube amp could make it sound even better.
Textfeud
- Apr 28, 2012
@jerick70 Around 750 euro.
@Keithpgdrb I’m using the HE-adapter right now to be safe. How does it change the sound?
LarsHP
IME bass is softer (not as hard hitting) with tube amps, but mids and treble might appeal more to you.
Take a look at the Anthem AMP 2 Special Edition. You will need to buy used but it is an excellent amp if you can find one.
Another option I found that sounded excellent with the HE6 was the Burson Timekeeper. You can find them for around your price at a dealer or used.
Keithpgdrb
- May 22, 2008
You only need the adapter with tube amps. I always feel like the sound is muffled rolled off in the top end.@jerick70 Around 750 euro.
jean-luc
I'm using the bakoon amp11r with my he6(6screw version).
Magic.
Magic.
Silent One
What silence said... then nothing.
- Aug 9, 2010
@Textfeud
It is my hope that you'll be able to have both chips & glass as oppose to selling the Yammy for tubes & HE-6. My HiFiMAN's sees duty with both solid-state and tubes. Absolutely love this contrast! I own the he-adapter but never used it on my monster receiver - always straight-to-taps, baby! In the beginning, I used the adapter to show my tube monaural amps a load for protection - had veiled sound. Then members here got me to strap the outputs with parallel (wirewound non-inductive) resistors. Now the he-6 straight to taps on both amps is yum-o!
HE-6> Sansui G-22000; Shindo Lab Sinhonia F2a monaural amps.
Textfeud
- Apr 28, 2012
I just plugged the HE-6 directly in the Yamaha CA-1000 headphone out with very good results. Not sure if there is a difference with the HE-adapter yet, will need to compare more. If there is it will be a small difference to my ears.
The right driver of my He-6 just died...crap.
I hope that hifiman still offer the service to fix it.
I wish you the best of luck sir. I hope they still have a couple spares left.
