My comment was regarding the actual mod of the pad, not the material used. I have put the cloth here:
... on the inner "walls" of the pads (as posted Dec. 7th 2016). If that is what you meant when describing your mod, then I obviously misunderstood your post. (I thought you put Sorbothane between the pad and the driver.) If you put Sorbothane the same place as I have put the cloth/fabric, then we have the same basic mod, but the material you used may be better at doing the job than my ordinary cloth/fabric.
EDIT:
After looking at some pictures, I am not sure that 2mm thick Sorbothane pieces would be better at dampening upper frequencies than cloth. And if the Sorbothane is mounted on the inner "wall" of the pads (as shown in the photo) it might even resonate with lower frequencies and particularly with bass punches because the leather/pleather of the pads are not a hard and firm baselayer for the Sorbothane. However, this is just theory.
Could you please post a macro-shot of the Sorbothane pads you use, so we can see what it looks like?
