drwlf
Instead of shooting from the hip as I've been doing, what you've recommended is a much better plan. I'd rather spend the $10 on rings versus possibly trashing the stock pads. Why would I want to do that I ask myself? The heating pad idea is also a good one too. Thank you for the alternative.
The more headtime I've had with these, they do sound very good. I just can't continue to A/B them against my other HP's one after another. Relatively speaking, they are very bass light when compared to my other cans, but when I truly listen for a good length of time, they really aren't that bass light. Getting used to the SS and just listening, they're very solid. Looking forward to swapping pads and EQ'ing.
I appreciate all the assistance from you all.
The stock pads don't have the removable ring, you'd be "trashing" them to get the ring separated, (albeit it's just slightly glued to the pads). The official velour pads have a removable ring, and it's the same price as the ring by itself, 10 bucks.
And yeah, the 400i are a bit on the thin side of cans, as discussed here previously Not that they're great for the money!
