bagwell359
I have never actually heard an HE6, but I hear it is very neutral with more impact than the HEX and HEK series. The problem is most with their current amps will not be able to hear it in it’s best.....if at all.
I think that 200 wpc thing is a bit over stated, IMO 6 wpc into 50 ohms is the max I used to get loud (program 93-94 db) and 3 wpc into 50 ohms is more than good enough most of the time.
The HEX and HEK have bass that goes low, but the raw impact feeling is muted a bit - under wraps. the HE-6 bass is like a waveform riding on a spear - SWHAP! It'll make you shut your eyes it's so intense. The highs of my HE-500 which I really like (physically almost the same as the HE-6) is missing a lot of detail compared to the 6. That treble can also be delivered with quite a large amount of authority. Never heard another can do that. The mids between the 50 and 6 are somewhat closer and the 6 isn't as forceful there - but I only had it in my system for about 30 hours - so maybe it is.
