Hifiman Ananda
Jun 28, 2018 at 3:34 PM Post #80 of 4,987
We need Susvara to not require nuclear power to drive it.
That's what the HE1000v2 is for. The SUSVARA isn't hard to drive for no reason, like the HE-6 and to a lesser extent the LCD-4. Dual magnet designs are harder to drive and stronger magnets probably make it harder to drive, among other things.
HE1000v2 at $2,000 would be more reasonable I think. Not sure how to price the SUSVARA, I have no experience with it but I'd guess no more than $3,000 which already puts it far above the Stax SR-007 which has significant inherent advantages.
Jun 28, 2018 at 5:26 PM Post #81 of 4,987
The LCD 4Z has the strongest dual-sided magnet structure to date and it can be driven with just a smart phone.
Jun 28, 2018 at 6:38 PM Post #83 of 4,987
https://diyaudioheaven.wordpress.com/headphones/measurements/hifiman/ananda/
The peak at 8.5k looks a bit daunting. Pad changes will help. Polite upper mids looks like.
Jun 28, 2018 at 7:41 PM Post #85 of 4,987
True but others can tell you about the compromise between the 4z and the 4.
I haven’t heard either. The LCD X and MX4 also have very powerful dual-sided magnets and low impedance with high sensitivity. The Empyrean, is also said to have powerful dual-sided magnets but only has an impedance of 35 ohms and a sensitivity of 100 db’s.
I just don’t know if it’s really the magnet structure that is the reason for the Susvara being so difficult to drive. You may be right, I don’t know.
Jun 28, 2018 at 7:43 PM Post #86 of 4,987
The HEX V2 I think had the same peak which bothered me a bit. Hopefully with a warmer tube will smooth those nasties out.
Jun 28, 2018 at 7:45 PM Post #87 of 4,987
I've been having a hard time finding a HE-6 to buy, seems like the V2 or the Ananda could be a better solution since I'm worried about longevity of used cans. Also, I haven't heard any e-stats in some time, might be time to play with stats again.
Jun 28, 2018 at 8:00 PM Post #88 of 4,987
The HEX V2 I think had the same peak which bothered me a bit. Hopefully with a warmer tube it will smooth those nasties out.
Yeah, cept I like jfets and such. That 10k peak in the HE-500 isn't that annoying but 8.5k is a more dangerous area. If it irritates me on female vocals - it'll never make it for me.
Hybrid tubes I used to use to relax CD's, but since the advent of the Gumby multibit,, haven't needed them.
Jun 28, 2018 at 8:03 PM Post #89 of 4,987
It definitely isn't the only factor, but it's beyond me to try to identify all. I sure would love to A/B both the HE1000v2 and SUSVARA with a balanced Dynahi amp though.
I think the older HiFiMan headphones like the HE-6 will last some time. Far more rugged build quality than say the Sundara and HE-560. I haven't read about many driver failures for the classic HiFiMans.
I may be selling my Code-6 in 2-3 weeks, depending on how it fares against the Stax SR-009.
Electrostats and planars are all I use. Though I will break this tradition with the ZMF Eikon soon.
Jun 28, 2018 at 8:21 PM Post #90 of 4,987
I used to have a pair of Stax 303 Classics - circa 1999. Imagine the latest generation shreds those.
Code-6 - yummy, better get my unused cans out there for sale to get my krona together... for the new or the old.
Don't like Sundara build quality, true.
