HTSkywalker
So it’s the 800 you are comparing to the S ?Yeah, I should have mentioned. My preferred genres are jazz, classical, acoustic and electronic. I rarely listen to rock.
BALANCED CABLE NEEDED - $120 MAX
I'd like some recs for Balanced cables for my Ananda. I was gonna get the ones from NewFantasia Direct on Amazon. But peeps on r/headphones said they aren't worth the money. Saying that "they worked". But some had issues with them. Shorts, excessive cable noise, uneven volume levels, etc.
If you've bought some from some place. And were happy with them. Drop me a link. Thanks.
You could always make your own for under that price. You'd get to pick your own connectors, and could do either canare/mogami/gotham or something fancier with that budget. It'd rival any of these budget cable makers and it's really not hard.
I might be wrong, but my understanding of balanced output to headphones is that it is all and only about output power, as balanced connection has two times voltage than single ended. Any transducer (speaker, headphone driver) requires only two wires: Plus/Minus. There is no use of the third one, isn't is? Another important thing is, if the output of the amplifier is truly differential (balanced). If not, then it can have XLR connectors, but the voltage will be the same as on single ended output. The input from DAC is not important, you can enjoy balanced output advantages even with single ended input - it depends on topology of the amp.Not sure if a balanced cable between the amp and cans would do any difference if the connection between the DAC and amp is non balanced using RCA.
Sure, but how this relates to headphone cable, where there is no use for ground signal? You decribed advantage of XLR signal cable, where I agree.In unbalanced cables, 1 wire carries the positive signal and the 2nd one carries both the negative signal along with the ground, In balanced cables, 1 Wire carries the Positive signal the 2nd carries the negative signal and the 3rd is dedicated for the ground.
Having a separate ground wire eliminates the interference and especially in long cable runs in studios or in heavily wired connections especially with close to power cables.
On short runs like in amp to can connections I don't believe it would make any audible difference for home use. Having a dual dedicated separately wired left and right amp architecture signals would do all the difference in the world even better when powered with a toroidal PS or dual ones coupled with dual DACs architecture.
