HiFiMAN 602: Talk about your initial impressions and specs
post-6967377
Post #361 of 1,195
immtbiker
The first to organize an (Inter)National Head-Fi Meet (2006)
Moderator
As I thought the line out is unaffected by changing gain which makes sense. I noticed it says "music" in the left top corner. I'm assuming if a video was stored on the player it could be recognized as a movie but obviously unable to be played.
Same thing with unrecognizable file formats. I downloaded a alac file (I knew it wouldn't work, but wanted to see what happened) and a 88 khtz file from Chesky, and it cycles through all of the songs endlessly, over and over, but doesn't declare a fault or lockup. As long as it doesn't lock up, I'm happy. I am so shell-shocked from "re-boot-itis" from my Dell Latitude 620 for work that the color blue is no longer appealing to me anymore
post-6967507
Post #362 of 1,195
.Sup
Ljubljana
Ljubljana
Age
34
immtbiker how long did it take for yours to fully recharge? I assume the battery indicator stops blinking when its recharged? I would like to listen to mine before I go to sleep and its currently still recharging.
post-6968063
Post #363 of 1,195
nickosiris
Herts, UK
Herts, UK
My 602 arrived yesterday, and overall I'm happy. Time will tell exactly how happy, but my initial impressions:
Warm. Dark. I like warm and dark!
Works with my Mac
Can't navigate by file structure, only by tag data
No problems with 32GB SD card
Feels oddly light and empty! I want to open it up and see what's going on in there!
Slightly smaller than I imagined. Definitely pocketable.
More soon.
post-6968222
Post #365 of 1,195
yooss
Can't navigate by file structure, only by tag data.
If it's impossible to navigate by file structure, how do we play .wav files?
post-6968252
Post #366 of 1,195
warp08
I can't talk about battery life yet, because as with all new Lithiums, it takes a couple of full cycles to maximize battery life on new components. The changeover to a 5 volt lightweight charger is a blessing, but let's not forget that the 1704 DAC consumes a huge amount of power and calls for a much larger battery. I would have liked to see a micro SD port for charging, so while traveling, I wouldn't have to use a separate charger, and just recharged off of my laptop.
Aaron, it does charge thru its USB/Exchange mini-USB port, when connected to a laptop.  Maybe not as fast as from its own charger but it does charge, nonetheless.
post-6968298
Post #367 of 1,195
EraserXIV
Can you comfortably wear the RE262 over the ear instead of straight down?
post-6968312
Post #368 of 1,195
Hero Kid
.Sup said:
Posting from my phone so bare with me. No, you cant wear them over your ear since there is no holder or anything just bare cable
post-6968320
Post #369 of 1,195
david1978jp
It should charge faster if you use an USB port wall charger with 1000 mA output.
post-6968410
Post #370 of 1,195
immtbiker
Moderator
I'm not sure. I left it plugged in overnight. Sorry.
I did not know that. Thanks for the great intel. That helps me on 3 day business trips involving hotel stays.
post-6968687
Post #371 of 1,195
.Sup
Ljubljana
Ljubljana
Age
34
In 2 hours the battery charged by half. I then went to bed so I disconnected 602 from power. Ofc I did some listening in bed with it before I fell asleep for sweeter dreams.
post-6968760
Post #372 of 1,195
warp08
"Half" could be misleading.  I was watching the discharge pattern during my initial rundown.  It went down to "Half" in about 2.5 hours and then stayed on it for the next 3, so the battery indicator does not change in a linear fashion.  This is no big deal, probably a bug in the code that calculates the bars based on actual remaining charge in the battery.
post-6968777
Post #373 of 1,195
asrphani
post-6968960
Post #374 of 1,195
nickosiris
Herts, UK
Herts, UK
I take that back actually. You can navigate by file structure (sort of) by manually adding "Flash On Board" to the main menu yourself. It's not there by default. A user manual might have helped me discover this sooner!
Does anyone know where I need to put pictures and what to name them if I want to use the two User Wallpaper settings? No big deal, but it would be nice to know.
I haven't really had enough time with this thing yet to form a full opinion, but it's been pretty obvious from minute one that this thing sounds absolutely fantastic. I've been checking out some 24 bit vinyl rips this afternoon and can't wipe the idiotic smile from my face...
post-6968962
Post #375 of 1,195
.Sup
Ljubljana
Ljubljana
Age
34
I also noticed that problem where not all my music was shown under "albums". Under artists everything was there but I was unable to select to play all songs, only songs from specific artists. However going into "settings" menu" and enabling "show flash on board" made all albums visible.
