Hidizs Sonata HD DAC cable - new tiny and mighty DAC&AMP
post-14743757
Post #376 of 810
Mellowship
Porto
Porto
Age
41
Hello All
After flashing to firmware D (pure music), I cannot get it to work on my Mate 10 Pro (Android - latest emui).
Do any of you know of a solution, other then downgrading the Sonata ?
If your developer options are activated, try resetting them and then try the sonata. Plug it in and fiddle with the usb options under the developer menu.
If this doesn't work, I guess the mate 10 pro is not compatible with d mode...
Reactions: Mnie88
post-14743760
Post #377 of 810
Mnie88
Denmark
Denmark
It is possible that the D firmware doesn't play nice with your phone for whatever reason. Maybe you can try flashing the A or C firmware to see if it makes a difference. Either way, the Sonata HD should work fine as an audio output device with the D firmware on your phone. Not sure what else to try other than contacting HIDIZS for support.
Yes, probably something with the phone not working with that specific firmware. Have send Hidizs a message, otherwise will downgrade firmware. Thanks for the help.
post-14744988
Post #378 of 810
tacit
There is another firmware lower on the page than A, C, D firmwares, called Hidizs Sonata HD DAC Cable_V2.0. Does anyone know what it is?
post-14745022
Post #379 of 810
Lifted Andreas
Formerly known as geko95gek.
United Kingdom
United Kingdom
Yeah they're just the ASIO drivers.
post-14745037
Post #380 of 810
tacit
Thank you very much!
post-14746335
Post #381 of 810
j0p3Y
When I have a completely new Tempotec Sonata, I don't know what firmware it is on.
Is it advised to install this ASIO-driver (V2) to be sure the device is on V2-driver software?
And after that, another flash to install one of the A, C or D firmwares?
Or is it that firmware is overwritten completely every time you flash? So an immediate flash to A, C or D firmware is sufficiënt?
post-14746709
Post #382 of 810
phiemon
I have many problems with the Sonata:
– the sound pops-up if I change the volume level or track.
– sometime the volume goes immediately high if I plug-in the Sonata.
– sometime I have to plug-out and plug-in the Sonata again in order to make it work.
Is all that "normal"? I've the Firmware D.
post-14746978
Post #383 of 810
RiflemanFirst
I have encountered these issues as well. Also using the D firmware. I have returned mine for a replacement to see if it was defective and should have the new one tonight.
post-14747021
Post #384 of 810
Lifted Andreas
United Kingdom
United Kingdom
Just flash the firmware you want. The ASIO drivers are obsolete, and don't work very well anyways.
My Sonata HDII came with A firmware installed as default.
post-14747100
Post #385 of 810
phiemon
Please report back if the new one is good.
Anyway, that Sonata Cable sounds to me better than the NextDrive Spectra.
post-14747376
Post #387 of 810
RiflemanFirst
The replacement arrived a few hours earlier than expected. Kudos to Amazon for that. Unfortunately the replacement unit behaves/sounds exactly the same as the first one. I'll probably just return the replacement for a refund. I bought it mostly for fun and to see what it is capable of. While it can drive all of my headphones with some headroom to spare, I have no use for a DAC/amp that doesn't output clean, artifact free sound.
post-14747385
Post #388 of 810
Lifted Andreas
United Kingdom
United Kingdom
I really have a feeling it might be your sources and not the DAC itself.
I don't get any artifacts with my unit with any of my sources.
Reactions: peter123
post-14747394
Post #389 of 810
phiemon
I have the same problem with the iPad Pro, the PC and the iPhone (via Lightning USB Adapter)
post-14747398
Post #390 of 810
Lifted Andreas
United Kingdom
United Kingdom
The only conclusion I can draw from that is the Apple connection. I use Android and my laptop, no artifacts of any kind. With your PC it could be a noisy USB port perhaps?
