Hidizs Sonata HD DAC cable - new tiny and mighty DAC&AMP
post-14707363
Post #286 of 810
Lifted Andreas
Formerly known as geko95gek.
United Kingdom
United Kingdom
Yes, if there is no accessorie cable by hidisz itself I will use sth like this. But I hoped for a solution from them.
Why would they supply something like that for a $30 device lol?
This tiny DAC was never supposed to support balanced output. If you want to experiment with adapters that's on you.
post-14707392
Post #287 of 810
Negakinu
World
World
A cheap way to try it would be the Fiio 3.5 male to 2.5 balanced female adapter:
post-14707507
Post #288 of 810
YZiya
Turkey/Ankara
Turkey/Ankara
Do any of you had chance to use both Sonata and Lg Hi-Fi Plus module. The price of both of them are quite close by in my country. (25 dollars)
I am planning to use the device both in my computer and also with my cell. I am a newcomer in the Hi-Fi domain.
Any suggestions would be really appreciated.
post-14707565
Post #289 of 810
Borghi
Does it play normally with headphones connected without DAC cable?
Could be because the Sonata DAC doesn't support MQA files? You need something like the Meridian 2 for that.
This DAC works totally fine of my Essential Phone. I don't use Tidal though.
It is my understanding that Tidal MQA files should play back on any DAC (but at a lower quality). I tried the RAZER DAC and the Essential DAC and the MQA files play fine on both of these. I plug in the Hidizs, and I get the same loud distorted sound from one channel. Here is an article that explaines that MQA files should play back on "non MQA" DAC's . https://audiophilereview.com/cd-dac-digital/mqa-master-streaming-on-tidal-rules.html
post-14707569
Post #290 of 810
Borghi
How do I connect wired headphones to the Essential phone without a DAC cable? The Essential phone does not have a headphone jack.
post-14708546
Post #291 of 810
Norway
Norway
I've got both and fwiw I think that the Hifi Plus module is superior it's actually really hiid and I prefer it even over something like the Shanling M1. That being said mine is connected to a LG G5 witch makes it a hell of a DAP with streaming for very little money. If I was to buy it to pair with another phone I'd get the Sonata HD for much better form factor and still sounding very good. Just my 2c....
Reactions: YZiya
post-14708883
Post #292 of 810
JammingMano
Malaysia
Malaysia
I complained about the exact same thing a few pages back. Mine is very hissy with my IEMs as well. I now use it once in a while with a less sensitive headphone, like my HD600. Not ideal, and kinda defeats the purpose of a portable rig. Oh well, you live and learn. Luckily it was dirt cheap. I actually ended up buying a Shanling M0 and stopped trying to mess with phone-DACs. :)
EDIT: someone on the Head-Fi Facebook just commented on the Sonata:
"Sonata HD has 32 ohms output impedance. Not very good if you have sensitive IEMs."
I see, I see!
I've not even thought about it having a pretty high output impedance compared to my IEMs that I usually use (Tin Audio T2s and Xiaomi QTEJ03JY).
I learnt something new today. Thanks for the information! :)
I guess I'll attempt to flip this, since I'm more of a budget audio user.
post-14709065
Post #293 of 810
YZiya
Turkey/Ankara
Turkey/Ankara
Your 2c is very appreciated sir :) I just want to make a small leap and then extend it after I got some experience.
I assume I can not go wrong with either of those.
Reactions: j0p3Y and peter123
post-14709945
Post #294 of 810
Norway
Norway
post-14711246
Post #295 of 810
Lifted Andreas
United Kingdom
United Kingdom
I actually like the Sonata HD2 so much I'm planning to sell my FiiO Q1ii that costs 3 times more lmao
Reactions: peter123
post-14711459
Post #296 of 810
Sylmar
As someone a-technical, can you just plug it in the phone and have better audio just out of the box?
post-14711463
Post #297 of 810
phiemon
Yep and if you have sensible IEM just should buy the IEMatch for a further better sound.
post-14713252
Post #300 of 810
Dobrescu George
Reviewer: AudiophileHeaven
Bucharest, Romania
Bucharest, Romania
Age
25
Website
audiophile-heaven.com
What counts as sensitive IEMs? Is 16ohm considered sensitive? Will I get hiss with them?
Certain IEMs are more sensitive to hiss than others, regardless of their impedance. For example, IE800 is quoted at 16 OHMs, but it is not sentisitive to hiss at all, while Ie8, from the same company, is incredibly sensitive to hiss
