goodvibes
- Dec 28, 2009
Have you tried UAPP integer upsampling? What rate have you been upsampling to 24/384-352 or higher? Use frequency multiples of the original if possible.In short, I have nothing but praise for RS6. I will upsample my favourite albums to the maximum resolution RS6 accepts as I hear its benefit. It might also have to do with the program I used. PGGB does extreme filtering using a Matlab upsampling algorithm. The files that I used were upsampling with 256 million taps.
- I just wanted to understand how the OS of RS6 functions and whether only MQA benefits from OS for now. It appears only MQA benefits from the OS feature of RS6.
- I also wanted to feed RS6 the maximum playback file it accepts and compares it to the same file OS by RS6; I hear a difference.
- Hibys OS is warmer and more forgiving.
- Direct 2xDXD playback has a sharper attack, better transient response.
- I made a significant error on my DSD test. It was not a deliberate error but accidental. I'm after an excellent offline DSD upsampler that does not cost 2,000 USD. I was trying to test how good the free PCMDSD program I found online function, and as a result, last night, I uploaded the wrong file into RS6. I wanted to compare the DSD256 I found on native DSD against the same file upsampled using that program.
- I still prefer DXD compared to DSD on RS6. It appears the program does extreme filtering for the ultrasonic freq.
I'm using the free version and seriously considering buying this program. I had bad luck with its foobar version, which is the lite version of the same program.
Conclusion:
Overall, I couldn't recommend this DAP enough. I understand now why MQA sound so good on RS6. For now, Hiby only OS MQA file, and other files appear to remain in NOS format.
I also hear the benefits of upsampling my favourite album to the maximum resolution RS6 support. The added benefit appears to be a better transit response that shines on classical music. The advantage becomes much more audible for live recording; the microdetail just stands out without ever being distracting.
Tonight I will compare PGGB with the free XiVero program and see whether the benefits I hear is because of the program or RS6.
Ther is a technical video on hibys weibo, I wish I understood it. Putting it here for those who might be able to translate it if they can.
https://video.weibo.com/show?fid=1034:4698669002457109
Please see above,
I'm sure Hiby has enough power in this unit to offer frequency dependent, multiplication of bits up sampling in their normal settings menu. This would be a great FW recommendation from those reviewers that agree with you.
