Whoever wants to go wireless with maximum quality (24bit/192KHz, 1.2Mbps by Bluetooth) - here is my thread and review (2nd post, spoiler) of HiBY W5
Hiby R6 Pro - serious upgrade to popular DAP
during shuffeling, I noticed that the album name is not shown directly on the display.
For albums without covers, it's rather cumbersome always to tap the properties item on the device to see this information.
Is there a solution for this ?
Doctordoom16
Anyone having trouble linking a Android phone w hiby app to the r6pro via hiby link? I've gotten both to recognize each other asking for a code but a message at bottom pops up that it's unrecognized
I had no problem w r3 and my Android phone But r6pro won't connect. It's international version and phone is essential phone w Android pi OS.
hornytoad
- Apr 17, 2016
Well i listened briefly the R6 Pro and the audio quality is amazing . I did run into emi interference when playing the device close to my very powerful Orbi Pro router. Interesting enough I turned my chair away( back towards the router) from the router and it
for the most part went away. I plan to use this device mostly for mobile so I am not too worried about the emi issue.
The Hiby has a gorgeous screen and the sound quality is better imo than the original R6 .
I did the update that fixed Tidal outputting at the incorrect sample rate but havent had time to check this.
The Pro is fairly heavy but I can still put it in my pocket no problem.
I will be comparing the 3.5 and 4.4 jacks in the next few days. . I listened briefly to the 4.4 and it sounds incredible.
Just tried it for the first time now it it worked just fine first time. International Rom. (This was using bluetooth)
rcoleman1
Curious about the delayed official release of the R6 Pro on the HiBy website.
Doctordoom16
Can you detail how you paired it w your phone. Maybe I'm missing something. ThNksTJust tried it for the first time now it it worked just fine first time. International Rom. (This was using bluetooth)
Doctordoom16
Thanks. I still cant pair them. Something is blocking the 2 from pairing. A white warning pops up ,"unknown remote devise." when i try.The code popped up on both my phone and R6Pro and tapped pair on both and they where then connected.
Not sure what else to do?
AudioDwebe
- May 1, 2006
Does the unit run warm when in use?
I currently have a DAP that gets so warm in my pocket that is gets somewhat uncomfortable.
Thanks.
Thanks.
Doctordoom16
only when plugged in and listening to itDoes the unit run warm when in use?
Thanks.
PDT1137
- Feb 28, 2011
Anyone know the 4.4mm balanced out pinout?
Can I assume it's the standard Pentaconn?
I'm not getting any signal out of the balanced out... just want to make sure it's a cable issue and hopefully not a player issue...
AudioDwebe
- May 1, 2006
Thank you.
PDT1137
- Feb 28, 2011
Apparently I'm weak and didn't push the connector in all the way... All is good
jeffry82
- Jul 24, 2016
Is there any different between r6 pro chinese fw and international fw except the play store?
Can we install any streaming music apk to chinese fw version?
