HiBy R6 III (Gen 3) Android digital audio player, Dual ES9038Q2M, Class A / AB amplification switch, Snapdragon 665, Open Android 12 OS, DSD512 / PCM768
Jun 14, 2023 at 12:13 PM Post #710 of 1,217
Jun 15, 2023 at 10:29 AM Post #715 of 1,217
Is this on HiBymusic app or?
Did you have some information on this?
Why it's not possible to control volume on external dongles or DACs?
This is based on Android and the same as a smartphone in theory. So it should be able to be used as the music player when connected to dongle. The HIBY R3 Pro Saber 2022 worked this way.
Jun 15, 2023 at 10:32 AM Post #716 of 1,217
ok waiting thanks
astell kern sr25 ii android too. but i dont found this menu settings to get bigger font
Here are examples of what the standard list looks like and if you increase the size in the hiby r6iii settings
Jun 16, 2023 at 5:32 AM Post #717 of 1,217
It's based on android but not the same as a smartphone, the underlying audio architecture was completely re-engineered compared to regular android to allow e.g. bitperfect output (no reaampling) and our system level audio DSPs. Unfortunately systemwide USB audio volume control was not programmed into this system, althought volume control is available in exclusive mode. We will try to program this in in the next update for this player.
Best regards,
Joe
Jun 16, 2023 at 5:42 AM Post #719 of 1,217
Best regards,
Joe
Thanks for replying 👌
Jun 16, 2023 at 10:02 PM Post #720 of 1,217
Hello to all. I purchased an Ibasso DX170 and a Hiby r6 lll. I’m keeping the Hiby R6 lll and sending the DX170 back.
Now I have a question if I may.
On Z-Reviews he mentions that there is a sound stage adjustment, where is this and what is it called???
Thanks in advance my fellow audiophile music lovers.
