Hi, I installed two widgets onto my android phone that kinda enhance Hiby R3 Pro's functionality: Bluetooth Audio Device widget and Material Music widget.
First one lets you create button for each BT device that you connect your phone with and some actions, so mine is called Hiby, and on click it enables BT, connects to Hiby and starts Tidal on phone, and on second click it switches off BT.
Second one kinda emulates Hiby Music app's widget, that does not exist, and works with Hiby Link. Well, "works". It is playback widget that lets you select previous and next song for Hiby Link without the need to open the app itself. The play and pause buttons on the widget do not work, instead they open the app. How to set second one up: Follow app's instructions, i.e. enable Notification listener permission (otherwise widget will not work with Hiby Music) through widget's General settings, and through widget's Player settings set Switch back to default player settings to Off, enable Hiby music player and set it up as Custom player 1 in Control Mode 3. All other control modes do not work for Hiby Music. Well 2nd control mode also works, but on play/pause click it switches off BT so keep it in control mode no.3. When you click on app icon on widget's top right corner, it can switch to another phone music app, f.e. Tidal on phone, in case you want to use Tidal on phone and Ldac it to your Hiby.
Enjoy your enhanced Hiby link's Tidal functionality (with 2nd widget) and phone's Tidal functionality (with both widgets).
