Help with SHN to FLAC Conversion
Aug 30, 2015 at 10:01 AM Thread Starter Post #1 of 2
Grateful76
Hey all. I just received a ton of live Grateful Dead from the 1970s but it's primarily in SHN file format. Can anyone suggest a program I can use on a basic laptop running Windows 10 with an Intel i5 processor that converts SHN to FLAC? Relatedly, is JRiver my best bet for a fairly straightforward program to play FLAC files on my laptop? Thanks in advance for any suggestions, sorry I'm a noob (if that wasn't glaringly apparent) to the world of FLAC.
Aug 30, 2015 at 12:11 PM Post #2 of 2
GotNoRice
Foobar2000 can play those files via a plugin.  You can then use Foobar2000 to convert into WAV, or directly into FLAC if you have it setup.
