- Jan 17, 2003
In anticipation of the D-303 I'm going to be getting (the money's definitely going out tomorrow! So don't worry, vwap.
) I want to start thinking about putting together a new system with the D-303 as the centerpiece.
The two sets of cans I currently use the most are Beyer DT-931 at home and Shure e2c or PX 200 on the road. My current amps are Xin SuperMini V6.2c, previous version Airhead and a mid level META42.
I anticipate using this primarily as a desktop/bedroom rig, although I would like to be able to use it portably. I guess my main question is what kind of amp should I use with the D-303? I don't want to give a budget right now because I will save/sell in order to finance something and I don't need to buy right away. What I'm wondering is how high up the ladder I should go. An Emmeline XP-7 or LaRocca Pocket Reference would be very nice but is that overkill with a pcdp? An amp that can be used with both batteries and a wall wart would be ideal.
Another option is using the optical out. Would I get better sound with an external DAC and an amp or wouldn't it be noticeable? Would it be worth it to buy something like the AOS Sostenuto-1 or Pace? Seems like a lot of money to put into a transportable rig.
As far as cans go, I'm happy with the DT-931 but if anyone can suggest a good headphone that has good synergy with the D-303 or a better phone that could be used portably, I'm all ears.
One more thing, is there such a thing as good quality portable speakers? Sometimes when I'm working I like to listen to background music but don't like to wear headphones.
Thanks for any and all advice.
