chewy4
- Jun 27, 2011
I've got a Samsung TV that has an audio out that looks like this: https://cnet2.cbsistatic.com/img/gj..._35159622_35159624_35159625_3515962606__3.JPG
And a regular 3.5mm to RCA cable that I'm trying to plug into it.
It doesn't quite fit. It's a little loose and doesn't go in all the way. It does output audio with it, just with a terrible buzzing noise along with it.
Are there different kinds of 3.5mm to RCA cables or is the output just bad? If there's a different kind of cable I'm supposed to put in there, what kind should it be? The manual only mentions using an analog audio cable.
