Help with headphone choice
post-845384
Thread Starter
Post #1 of 9
Liver
Hello and welcome to my first post.
Been reading several posts and I have realized that my Sennheiser HD 570 headphones are not that well regarded.
Sure they sounded way better than the generic headphones that I had, but I realize that the difference in sonic quality can be greatly improved.
I have been reading and think that I will get either the Sont CD3000 or the Alessandro (most likely my spelling is off) First series ($99) or the seond tier ($299).
I generally listen to all sorts of music from rock, rap, country and classic. I even enjoy watching movies with the sound via headphones. I like the "coccoon" effect that headphones create. I listen to CDs, MP3s and whatever through it.
Driving my headphones I have a hand made PIMETA (made by Ivan, not me). All signals are digital into my DAC and then into the PIMETA.
The catch is that there I have to get them un heard. What do you guys recommend?
If not these two choices then I am open to others as well. But if between these choices?
Liver.
post-845437
Post #2 of 9
blessingx
HeadFest '07 Graphic Designer
Supplier of fine logos! His visions of Head-Fi
Welcome to Head-Fi.
Out of your choices, I think the CD3Ks are the most coccoon-like, but with your amp, maybe the Alessandros are best. CD3K may be overkill. As for the MS1 or MS2, can't say.
post-845481
Post #3 of 9
joelongwood
Keeper of the 'Phones
Moderator
For listening to movies, I prefer the CD3000 over the other 'phones I have. For semi-closed cans, the soundstage is HUGE! Also, they're not too shabby with general music as well. Hope this helps.
post-845742
Post #4 of 9
Liver
All suggestions help.
Overkill? Overkill? That is just another reason to upgrade! Really though, I think that you may be right about the Sony's being in a class of their own in regards to my amplifier.
I have found an Internet reseller that has a trial period for the Sony's, so I may be doing that. Best demo is in home demo.
Thanks.
Liver.
post-845774
Post #5 of 9
commando
The CD3K should be fine with your pimeta, I didn't notice much of a difference between my pimeta and ppa. CD3K should be fine for most types of music, the alessandros more for rock.
post-845775
Post #6 of 9
HiGHFLYiN9
Member of the Trade: Zynsonix
East Coast
East Coast
Website
www.zynsonix.com
From what I've read the CD3000s and Grados are either hit or miss. There are a large number of people that feel that the CD3000s are too bright, and that grado based phones are bright and uncomfortable. $300-400 seems like a lot of money to gamble with, if you can't arrange an audition I would suggest you go with a more nuetral pair of cans at first so you aren't stuck with something you don't like. You may want to persue a pair of K501s, they are $125 on Ebay and aren't as polarizing as the other two phones you're considering.
post-845785
Post #7 of 9
pedxing
As long as you don't mind spending the extra bucks, I would go for the Sony CD3000. From someone who is use to listening to such comfortable headphones as the HD570, you may have transition problems upgrading to a sony CD3000.
post-845789
Post #8 of 9
commando
It depends if you interpret the CD3Ks highs as detailed or bright. Personally I find them detailed, but that's just me.
That doesn't seem to make sense to me - go for the CD3K, but you might have transition problems because of comfort? The CD3Ks are very comfortable.
post-845794
Post #9 of 9
joelongwood
Moderator
Most definitely!
