1mark2
- Jun 17, 2016
Hi! So I'm planning to buy some new headphones, but unfortunately in my country only very limited options are available and shipping from other countries would likely double the price due to taxes so I'm stuck (my budget is also quite low)
Now the options available here in my price range are the Sennheiser HD 439 , Sony XB 450 (both priced the same) or the pricier HD461i. All other options here are either Beats or Skullcandy which I don't think are worth the money.
I listen to Electronic Music, orchestral music and sometimes pop and I'll mostly be using the headset on the bus
Do you think any of the options are worth it or do I just stick with the samsung IEMs that came with my phone until I can afford sth better ?
