Joshatdot
I might redesign the board for Panasonic ECQ-E2105KB input cap. It's 1.0uF 250vdc with only 12.5mm lead spacing.
Originally Posted by Joshatdot /img/forum/go_quote.gif Can PCB manufactures make the board with 45 degree angled corners? |
Originally Posted by infinitesymphony /img/forum/go_quote.gif Joshatdot, any plans to make a number of boards for sale? ![]() |
Originally Posted by Joshatdot /img/forum/go_quote.gif This what I am planning to do. I just need to finalize a design & layout. |
Originally Posted by AndrewFischer /img/forum/go_quote.gif If you use a single power supply cap you'd have more room. You don't need two in series. I think it would simplify the layout too. Try and think about routing when you place the parts. Eagle's autorouter isn't very good. There is room for improvement. |
Originally Posted by infinitesymphony /img/forum/go_quote.gif Any chance you could sell some pre-routed mint tins, too? Those things are a PITA. ![]() |
Originally Posted by MisterX /img/forum/go_quote.gif Two quick "questions".... Where are the R5s? (I can assure you that nobody that owns IEMs will be happy with the results if you leave those resistors out) Why are you limiting your design to just use "stable" Jfet type op-amps? (2 small ceramic 1206 SMD bypass caps is all it will take to make high current bipolar op-amps play nice and they are dirt cheap) I would suggest the you keep the inputs caps small. (9mm X 5mm is fine) Remember those caps are optional parts afterall. ![]() |
Originally Posted by Joshatdot /img/forum/go_quote.gif I've been using the same schmatic for all these board layouts so far. I am going to redesign it from scratch. I am thinking I can get by with a single 470uF 16vDC |
Brands are: Nichicon, United Chemi-Con & Panasonic - ECG. Will it matter what one to use? |
Originally Posted by Joshatdot /img/forum/go_quote.gif What brand and models of bipolar op-amps do you recommend? |
