Help with choosing a IEM
Oct 9, 2009 at 8:32 AM Thread Starter Post #1 of 3
audionub
Hi Guys,
I'm thinking about upgrading from my current earbuds (CX-300).
And after doing some research online im tring to choose between the Shure se210 and Ultimate Ears SuperFi 3, unless you guys think that theres a better product out there. After going through the forum I'm also considering some entry level westones although I'm going to have to import them to Australia.
As you can tell my budget is around the mid 100's mark.
The buds are going to be directly hooked up to an iphone 3gs or a 4th gen nano.
The music I mostly listen to is RnB Hip hop, some light rock (linkin park, coldplay), and pop.
So some good base is disired.
Edit: I know theres a lot of these kinds of posts around but Thanx in advance for your comments.
Oct 9, 2009 at 3:41 PM Post #3 of 3
Sebastianbf
are you ok with buying used IEMS? If so, you should take a look at the for sale section. For that money you can get IEMs that are miles away better, like some shure e4
