Help with 580 recable
Aug 18, 2007 at 6:17 PM Thread Starter Post #1 of 4
mnamo
Hi everyone, so I decided to recable my 580's with cryo treated mogami 2534 and neutrik plug wrapped in nylon multifilament.I already got everything and I'm almost done with soldering,.One thing left is to solder the plug.Now I'm confused with what should I solder to where and need some help.What i did already is I connected white and blue wires to the pin connector for left and right.So white and blue to the left pin connector and white and blue to the right pin connector.White to the thicker pin on both sides.Now I would think that i should connect them to the plug like this:
left white and blue pair to the left plug pin
right white and blue pair to the right plug pin
copper shield to the ground plug pin
Now I'm not sure if that's ok and i don't want to mes it up so please can someone clear that for me.It's been 3 days without my headphones and I can't wait much longer:] Thanks
Aug 19, 2007 at 12:12 AM Post #3 of 4
If the thicker pin on the Senn connector is +, then you should solder the left white wire to the center solder point, the right white wire to the next solder point, and the blue wires and the shield to the ground solder area.
Aug 19, 2007 at 1:38 AM Post #4 of 4
thanks for the help but I already figured it out on my own and I'm enjoying my 580's with new cable now:] To early to give some reviews though it needs to burn in(well punchier bass for sure).
