Help! Why do some earbuds feel harsh and aggressive, like there's more power in them?
Nov 19, 2018 at 2:02 PM Thread Starter Post #1 of 12
James H
UK
For the last 15 years I've been very happily using a pair of Sennheiser MX400 earbuds. They always felt gentle and comfortable, no matter how loud I had the volume.
They recently broke and I've been looking for a replacement, but the two I've tried so far (the VE Monk Plus and Sennheiser MX365) both have the same problem: They both feel really "harsh" and "aggressive" - even at low volumes. It's like they're attacking my ears!
It somehow feels like there's more power or electricity in my ears. Another thing is that they hurt my ears after a few minutes, even at low volumes. (I should mention I am highly sensitive to electrical fields - for example I can't put any kind of telephone near my ear as it quickly gives me ear ache.)
Does anyone know what I'm describing here? What's making the difference between gentle and harsh earbuds? Could it be some kind of electrical issue? Are modern earbuds "wired" differently somehow?
I really just want a nice pair of gentle earbuds like my old MX400s, but sadly they're no longer on sale!
Nov 19, 2018 at 4:39 PM Post #2 of 12
Nov 20, 2018 at 1:38 AM Post #5 of 12
Hi @James H,
Just wondering, what are you using as source & on the headphone plug, how many rings are there?
Do you have the same issue with headphones?
Some devices & headphones / earbuds / earphones are more sensitive to electrical signals than their counterparts (impedence, sensitivity, tuning, etc) so this may be a factor as well.
I ask as the VE Monk Series are offered with balanced connection in both 3.5 mm & 2.5 mm (at least 3 rings), even 4.4 mm...
Which essentially means, without getting too technical, balanced connections are able to carry more power in the audio signal so this might be what you are experiencing & have to be grounded differently to single ended (2 rings).
Regarding sensitivty to electric fields, when you use a handphone, have you tried a bluetooth headset to see whether this reduces your sensitivity.
Last thing, when you say harsh vs gentle, you are referring to 'feeling' the electrical field, right, not the sound quality?
Hope you have a great day !
Nov 20, 2018 at 5:47 AM Post #6 of 12
Hi Pagan, thanks for the reply! :)
What you said about balanced connections and rings is interesting, but I don't think that can be the issue. I've just checked, and ALL my headphones seem to have identical plugs, with two black rings round them. The VE Monk Plus is no different and looks like this:
https://www.amazon.com/Venture-Electronics-MONK-earbud-earphone/dp/B01J0S4AAS
Yes, I do mean the feeling. The sound of my Sennheiser 365s is excellent, but it just feels like my ears are being attacked somehow, that's the best I can describe it.
> what are you using as source?
Plugged straight into the back of my motherboard, via a small extension cable.
I'd imagine headphones are less problematic for me as the electronics aren't right in my ear, but I haven't tried them as I don't like anything sitting on my head. Though I suppose I could consider headphones as a last resort.
I'm pretty sure I'd have a problem with a bluetooth headset as my body doesn't react well to close proximity to electrical devices (just holding a mobile phone makes my hand burn - seriously). But it doesn't really matter anyway, I don't make phone calls and don't need to. If I do have an urgent call to make, I use a landline on speakerphone! :)
Nov 20, 2018 at 5:52 AM Post #7 of 12
Also, are you having these electrical problems sitting at home/desk or while moving/walking/out and about?
Nov 20, 2018 at 8:18 AM Post #8 of 12
Hi @James H,
No problem.
I am quite familiar with Venture Electronics gear but nevertheless, just in case, I wanted to be sure, so you have standard unbalanced which should be more than fine...
However, you may not be aware but VE has stated many times on headfi as well as their own message system their earbuds take more signal current than most would expect due to the way it is tuned as well as general specs.
So any source with a high current should generally be avoided unless properly grounded at the head out.
Monk Plus can get loud really easy as it has a high sensitivity rating despite mid range impedence which is why they tend to 'sound' better than most earbuds but I digress...
That is correct, I was referring to electrical field, as suggested with harsh vs gentle regarding 'feeling' the electrical field, other queries come to mind from your answer.
How loud do you usually listen to when on your computer through the earbuds?
How well fitted are the earbuds in your ear?
By any chance, without getting too personal, do you have lots of hair in your ears?
Also it could just be the earbud foam reacting or 'tickling' air pressure & electrical current as the audio signal passes from the earbuds into your ear.
Okay, now it seems we have found a legitimate concern regarding source, I hope whatever you're plugging into 'straight into the back of my motherboard' is actually the headphone jack & not anything else, eg directly into the board, etc.
Usually, anything not suitable for audio wouldn't be grounded properly or more likely, at all for an audio signal.
Not to mention general electrical interference which goes through most boards anyway.
If anything else, at the very least, you are giving yourself a tiny electric shock each time
At worst, something more seriously harmful could happen or if a short on the board occurs, you would more than likely go deaf &/or worse from any feedback or electrical discharge.
Also, any extension cable should be not only properly grounded within its own wiring but should also only be for audio use, not anything else, I am curious, please provide a photo & or brand name, url link, etc for this cable since we are diagnosing possible issues along your audio chain.
So you haven't tried headphones to replicate the same issue you have with earbuds, just because you 'don't like anything sitting on your head', this is not a critiscism though I am curious why you didn't see if a possible comparison could be drawn to see if you are affected the same way.
I would suggest trying headphones in general & not necessarily as you described on your usual 'plugged straight into the back of my motherboard' option to see if the issue is replicated via headphones.
For now, we will disregard this particular issue.
Nov 20, 2018 at 9:04 AM Post #9 of 12
Do you still have the same problem when you don't use the extension cable?
Cheap extension cables can severely degrade sound quality. It might just be that.
Nov 20, 2018 at 10:51 AM Post #10 of 12
Thank you both so much for trying to help me, I really appreciate it. I sometimes get a lot of rude people mocking me for claiming to be sensitive to electrical fields - they think I'm a nut, or making it up. But believe me there's no way I would make this up. I hate the idea of having a problem with my new earbuds - I WANT them to be great!
I've mentioned the Monk Plus earbuds, but I want to clarify that I don't intend to use the Monks. They were the first replacement I bought when my old ones broke (following a recommendation here on this forum), but I was extremely disappointed with them and I will not be using them again.
I had all kinds of problems with the Monks' sound quality, but the biggest was the non-existent stereo detail (they almost sounded mono to me). They also have a horrible echo in the buds, which muddies all the sound. So given that I adored my old Sennheisers, the next pair I decided to try was the Sennheiser MX365, for only £17, and the difference from the Monks was like night and day. The sound is perfect - it's just the 'feeling' I don't like.
Anyway, let me answer a few questions…
Yes, I meant the headphone jack on my motherboard. (Sorry about the confusion.) I mean the standard green port at the back - which my motherboard's manual says is for headphones.
All the earbuds I've used seem to fit fine, though I don't mind it being a little on the loose side - I've tried IEMs and find them really creepy and horrible. I don't like things shoved into my ear.
Do you have lots of hair in your ears?
None, as far as I know. Good idea though.
The reason I haven't tried headphones is because it would mean me buying some headphones, and I don't have much money and don't even like headphones! I suppose I could find a really cheap pair to test, but since I don't even want to use headphones it seems pointless.
If you mean foam covers, I never use them and don't like them. I like nice solid plastic. :)
I always start on a low volume then turn it up gradually as my ears warm up. I often end up with it quite loud, but I am very cautious about how I treat my body, and I know what my ears can take. For example, if a motorcycle drives past me on the street, I always put my fingers in my ears because the sudden loud noise is too much for me. I am very familiar with all the volume settings on my software, I know what levels are acceptable, and I don't allow any sudden spikes in volume. In 15 years of using my old earbuds, I never had any incident of feeling I'd listened too loudly, they always seemed "mild" even at high volumes :)
I only ever listen sitting at my desk. I'm a part-time music producer (on a budget) so I need to hear clearly for the work that I do. It's rare that I listen to other people's music for pleasure, I'm mostly just listening to my own music while composing and mixing the tracks. I know that ear buds are pretty unconventional for music production, but I just love them and don't want anything else. (It has to be open buds too so I can hear myself singing, playing instruments etc.) I sometimes listen on my big monitors too, but most the time I've got my earbuds in.
VE has stated many times on headfi as well as their own message system their earbuds take more signal current than most would expect due to the way it is tuned as well as general specs. So any source with a high current should generally be avoided unless properly grounded at the head out.
That is absolutely fascinating and could well be my problem! Though I really don't know anything about electronics, current, impedance, etc.
Is there any way to test what kind of current is coming out of my headphone jack, or out of the extension cable? And what exactly do you mean by "grounded"? How might I go about grounding my earbuds?
Do you still have the same problem when you don't use the extension cable? Cheap extension cables can severely degrade sound quality.
Thank you both - that's really interesting, and something I hadn't even thought of!
My extension cable is a really cheap one I bought for a few pounds and I can't even remember where!
At first I thought the extension cable couldn't possibly have anything to do with this, because I've always used the same extension cable, even when I was happy with my earbuds. But perhaps the problem could be caused by the cable and earbuds in TANDEM? The cheap cable might be letting too much current through, and my new earbuds are taking more current than the old earbuds did? To be honest, I don't even know what "current" means but I feel this is some kind of electrical problem.
It would be interesting to have some statistics on how much current various models of earbuds take! Perhaps it might turn out that the MX400s take a lot less than the MX365s?
I will also have to try and test my earbuds sometime soon without the extension cable, but it's not too easy as my PC is situated a little distance from my desk (to keep noise to a minimum).
Nov 20, 2018 at 11:09 PM Post #11 of 12
@James H,
Being sensitive to electric fields is a very real thing & there is enough documentation, case studies, etc which support this, most people tend not to bother with research, etc regarding all manner of subjects but I digress...
Before we get into anything further, I would suggest addressing some points regarding the following statements :
Point 1
Please read any basic GSC textbook on Electronic Theory before you go any further in what you are doing with the earbuds as you may harm yourself or others in the process otherwise.
Point 2
Please refer to my answer to Point 1.
Point 3
Yes, to test electrical currents &/or voltage, there are such things called a voltage tester or multimeter exists, go find one.
Point 4
Honestly, this does not make any sense, your ears are not a vehicle & should not be treated as such so there is no need to 'idle the engine', there is no such thing as what you describe & you are actually doing more harm than good.
This tells me a few things about your hearing practices, the most important being you have no idea what your listening level is.
You should have at least a rough idea how many decibels you listen at, especially if you say your part time gig is a music producer.
Good Sound Levels are essential in your work & I would be curious to find out what you find 'acceptable'.
Also, how do you control volume spikes?
A DB Meter will help with all this & I suggest you get this as well if you want to continue in this line.
Also, when you say ''mild' even at high volumes' essentially, this means you are potentially making yourself deaf over time, if you haven't already.
How long do you spend listening to whatever you're listening to in a given period, is it more than than 3 to 4 hours at a stretch?
If so, I repeat, you are causing yourself SERIOUS HARM.
General hearing health guidelines state if a sound is more than 80 db for more than 3 hours then harm is being done to your hearing.
I would suggest looking for these guidelines to get a better idea.
Point 5
Cheap cables often do more harm than good, I suggest looking into a better cable if you persist with this.
Inexpensive cables on the other hand, should generally work better, get something decent from any pro audio shop & you should be fine, average you should have to spend more than £ 10 off the shelf.
Pro Audio brands to look into are Hosa or Canare cables with Neutrik connectors.
Belkin is the only consumer brand which comes to mind which is inexpensive & decent.
Point 6
These 'statistics' as you call them exist, they are called Specifications, ALL PRODUCTS have them.
Point 7
What is this noise you speak of you need to keep to a minimum?
Point 8
Okay, I figured as much but regarding the headphone jack on your motherboard or with such head jacks in general, it is well documented motherboard headphone jacks are not a good option for conveying any sound, let alone any good sound, period.
This is due to Electromagnetic Interference, grounding issues, etc.
I mentioned general electrical interference which goes through motherboards & this will definitely be picked up with onboard sound.
To alleviate this or remove it, usually a dedicated sound card or my preference & what most music professionals would choose is something like a USB Computer Interface such as Lexicon Alpha or any of the Scarlett Series.
Of course, there are countless others but these the two brands I mentioned are the most value for money.
I would suggest looking into these to help at least alleviate your issues with electric fields especially if you are taking music production seriously.
This way, you would also remove the need for an extension cable for your earphones as the headphone jacks on any of these will help provide the best audio output.
While on the top of music production, I'm curious, what DAW do you use?
Reaper? Audacity? Pro Tools? Steinberg?
Any of these music production software has specific requirements & limitations, what happens when you encounter an issue.
Point 9
As stated before in my intial reply, due to tuning & other specs, VE Monks fit & serve a specific case which we now established isn't yours & also specifically requires a good source (not yours with onboard sound & the electrical interference from said board) to sound their best which I get is also personal & subjective.
This is why there is a 'horrible echo'.
Also, VE recommends a 'burn in' period of up to 100 hours, whether you believe in burn in or not is largely irrelevant as normal usage at reasonable volume should help the drivers 'settle'.
But then, generally, earbuds are not known for having stereo detail as a general rule but there are exceptions & would only sound mono mainly due to your source & electrical interference being some cause to this as well as how good the channel separation & articulation of the mixes are between left & right channel, not to mention SNR & THD, etc
Honestly, I am not aware of many, if any music production professionals, who use earbuds to do their mixes, etc
If they do, it is only for testing, not actual mixing, producing, mastering, etc so you may very well be a unique case & I would be curious to hear any work you've done so far or been a part of, please provide links if you can.
Point 10
Where fit is concerned, this seems to be a problem many experience with various head gear, be it earbuds, IEMs, headphones, a good comforrtable fit in important first & foremost before anything else, even before sound quality which is highly subjective & highly personal. If something is loose, doesn't matter what it is, even let's say, of topic, shoes or trousers, depending on your preferences and use, it is not necessarily a good thing...
Anyway, loose fit head gear, will not convey said head gear to the best of its ability, whether you like it or not is most certainly a factor but if it doesn't fit well in the first place, it's really not much point.
For example, IEMs are similar in that regard, a good seal is important, fine you don't like things in your ears for the very reason you stated, there are people who feel the same.
That's the problem most people have with IEMs &/or earbuds as the general concensus is to 'shove them in your ear', this DEFINITELY DO NOT DO as you are also potentially causing damage to your ear canal if you apply unnecessary force.
This is among many reasons why companies provide so many eartips of different materials as well as aftermarket ear tips being available, etc.
The important thing is to get the right size for your ear, (it may be bigger, smaller or even odd size, one ear using a different size to the other) gently place them in there until there is a comfortable seal & that's basically it.
As long as it stays there without being 'intrusive' in the sense of being uncomfortable then it should be a good match.
That is even before listening to any sound.
There are some people who have, after trial & error, especially after good advice have found they actually enjoy IEMs more than headphones for various reasons but that's another story...
Point 11
If you don't want to get headphones, fine, no one is making you get them but I suggest as in my intial answer, to see if the same effect is replicated, go to any store which do audio gear demos & try it there.
If there is an issue regarding the electrical field, at least you know.
Point 12
This statement is a problem, there are too many people on headfi who say this exact same thing for different reasons & honestly, often have unrealistic unexpectations with regards to whatever gear they may have &/or interested in.
To avoid any misunderstanding, I would be curious to find out your requirements regarding your listening needs &/or preferences in greater detail in a point by point list as from what I gathered to this point is by far the complete picture.
Let me give you some criteria to help you break it down clearly.
- Budget
- Use
- Listening Preferences
- Listening Area Conditions
- Any miscellaneous issues which do not fit into the first four criteria
Hope this clarifies some more things for you, be curious on what your answers may be.
Nov 21, 2018 at 12:53 PM Post #12 of 12
Wow, that is a lot of helpful information, thank you, Pagan. I'm really glad I've been able to speak to you! :)
That's very reassuring to hear. I've never met anyone else who is affected like fields like me. A lot of people just seem to think I'm crazy, and I've suffered a lot of abuse and ridicule over the years.
I'll see what I can do, but I wouldn't imagine there being too much harm from plugging consumer earbuds into the regular headphone port of a computer. Isn't that just normal usage?
Thank you, I will consider getting one in the future though have no money at the moment.
I will take your warning on board, thanks.
You should have at least a rough idea how many decibels you listen at… A DB Meter will help with all this & I suggest you get this as well if you want to continue in this line.
I will consider getting a DB meter in the future when I have more money, and that might be helpful. However, call me cynical but I don't place too much value on the recommendations of "guidelines" or industry experts etc. I've learned not to trust organizations and industries with my health - these are the same kind of industries that endorse all kinds of things I know are harmful to me, including telephones which don't suit my body at least. (There are also many things put in food that are deemed "safe" by health authorities that I would not eat.)
When it comes to my health, I simply don't trust other people (especially when there's money involved) and prefer to go on what my own body tells me - which is why I'm here making this thread in the first place, because my body tells me that something is wrong with my earbuds.
I've just had a look through several different online guides describing of the volume of various decibel levels, and based on this, I would say that my listening volume level is somewhere between 60 and 80 dB, generally around the low 70s. Though that is only a rough estimation.
From all the descriptions I read, I do not think I would be able to stand 80dB or more for very long. I think I'm more intolerant to loud volumes than most people as I've visited many music venues where I had to leave because I found the volume way too loud.
Well I've learned how to use my software to ensure there are no sudden jumps in volume - that's very important to me. Also I never have my volume set higher than a certain level which I know I'm comfortable with, even when the harshest, loudest sounds are playing. Plus the music I make is gentle music without any harsh noises or abrupt changes in volume. And when I play back other people's music, I always have it highly compressed, so the level is consistent.
On days when I'm doing my music, it's normally an hour or two, perhaps three on rare occasions but rarely more. And that whole time isn't constant loud music, there's plenty of quiet music, and plenty of breaks when I'm not actually playing anything. My music doesn't occupy a huge portion of my time, but it is an important part nonetheless, and something I'd like to do more of in the future, as I love making music.
Thank you! :)
That's great. Could you please tell me what particular specification I would be looking for in order to find out how much signal current a pair of earbuds will take?
I mean the noise of the PC. I specifically built my PC to be ultra-quiet, with an ultra-quiet case, so it is a quiet computer, but there are still obviously fans and hard drives making noise inside, maybe about 20–30dB from where I sit.
it is well documented motherboard headphone jacks are not a good option for conveying any sound, let alone any good sound, period. This is due to Electromagnetic Interference, grounding issues, etc.
I had no idea about that. and that is very interesting.
As for electromagnetic interference in the signal, I don't really feel I'm getting any. My signal sounds absolutely fine to me, and even if there was some interference, I don't really care to be honest. There's a LOT more noise interference from other sources, namely the noise of the computer, traffic outside, wind and rain, and I'm fine with that. I don't need my listening experience to be completely sterile.
Firstly, thank you for your recommendation, that is great. I've had a look at these USB audio interfaces you mention and it seems to me that the main reasons to buy them are for connecting microphones or speakers, neither of which I really use. (My music is mostly instrumental, and I have a small amp for my speakers and it works fine when I need it.)
Therefore, the only reason I would want a USB audio interface would be for the sake of guarding my ears from the physical effects of electromagnetic interference. I can't help but wonder if there's a simpler and cheaper way to do this? Like just "grounding" the cable which you mentioned before. (If money were no object, I'd just buy a USB interface but I just can't spend any unnecessary money at the moment as I'm struggling just to get by.)
It's a relatively unknown DAW called Renoise, but the only DAW I personally feel is right for me. (I am quite unconventional, as you may have gathered.)
All I can say is that my old Sennheiser MX400 earbuds honestly gave me wonderful stereo detail which I was happy with, so I know it is possible with my setup.
Yes I am very unconventional, and fine with that. Creativity and innovation are often the result of unconventional people who buck trends and go off and do "strange" things :)
It's tempting but I will pass on that if you don't mind. I'm not really looking to be personally identified here, and while I have spent my life making music at an amateur level, at the moment I only have a small commercial portfolio that's been properly produced.
Also bear in mind that when mastering, I use both earbuds and my monitors, as well as testing my music on a variety of speakers and devices. Also bear in mind that a large proportion of listeners use earbuds, so music produced with earbuds is perfect for those end listeners!
Thank you, that might be worth trying sometime. Like I said, I would consider headphones as a last resort, if I can't obtain a pair of earbuds I'm comfortable with.
I would be curious to find out your requirements regarding your listening needs &/or preferences in greater detail in a point by point list …
- Budget
At the moment money is very tight and I've already paid out for two pairs of earbuds this year (£12 and £17) so I'd be hoping for something around that price region, especially given that I paid less than £10 for the Sennheisers that I've loved using over the years, and just want something else like them.
Not sure what is meant by this question, sorry. My use is for producing music? Average an hour per day.
Again, not too sure how to answer this. Listening to other people's music for enjoyment is not something I do very much, and when I do, any old speaker will do, I don't care about sound quality. I don't really consider myself a consumer of music, only a producer.
At my desk in a quiet room.
All I really want from a pair of earbuds is an accurate, balanced representation of the source without any bias. I've seen a lot of earbud packaging that - worryingly - seems to indicate the bass is disproportionately loud. I've seen packaging which says "powerful bass" - that is a definite red flag for me! I just want everything evenly balanced, so that when I play low C it sounds exactly the same volume as high C. And, obviously, I don't want a "harsh" or "aggressive" electrical feeling. I want something that's gentle to my ears :)
