Mickj7
- Sep 18, 2007
Hi this is my first post, and I've joined primarily to get advice from you experienced users.
I'm looking for a pair of headphones which I'll be able to use with my integrated amp, and which my son will be able to use in the home with his ipod or to use with the TV. I won't be using them on the move.
I will be listening to quite a lot of vinyl through them although I don't know if this makes any difference, although I would like to listen to other sources too. my musical tastes are very varied, although I listen to a lot of reggae,blues,British indie pop etc.
I really like what I've heard about the HD650 but I'm not sure if they would be suitable for the uses I need. I get them for around £160.00 ($320.00) here in the UK. The HD595 can be bought for around £70.00 ($140.00) but I'm worried that they may sound aggressive,especially in the top end. I can't stand bright sounding music so I suppose the grado's are out of the question. I noticed the Allessandro is around £50.00 but again I'm not sure if they're bright or aggressive.
I used to have some Sennheisers which were HD570 (symphony) I think, but I gave them to my Dad who is hard of hearing to listen to the TV.
I liked them although they sounded a tad dull when hooked up to my integrated amp and I also had to turn the volume quite high to get a decent volume.
Any suggestions would be welcome.I don't really want to go down the route of headphone amplifiers if I can help it as I'm not sure of the costs it would involve. I'd love to get the HD650 but not sure if they would be suitable.The maker of my amp(MacIntosh) said it would drive the HD650 but I'm not sure.
many thanks for any help you can provide,
regards,
Mick.
regards,
Mick.
