AKGman
- May 19, 2015
Does anyone know if it is possible to tell if a STAX amp can have its voltage input modified internally (by changing the positions of the metal cylinders (jumpers) in the fuse holders on the circuit board?
I know that you can't modify voltage on amps that have a white "AC 100V ONLY" sticker on the back.
I have heard that for some STAX amps (which have for example, a black "100V" sticker on the back of the amp), you can do this, and some, you can't.
Is it possible to tell, just by looking at the back of the amp?
