Help Sony Vs ATH
  1. JediMa70
    Hello i'm thinking to buy a set of headphones BT not too pricey, ( I hate jabra move..) which is the best between Sony MDR-XB650BT and Audio Technica ATH-AR3BT?
    thank you
  2. yong_shun
    Are you a bass head? If yes, then MDR-XB650BT is a good choice! You can consider Sennheiser HD4.40BT as well. I find it very comfortable and the build is more premium as compared to Sony.
    serman005 and JediMa70 like this.
  3. JediMa70
    Not really but i like bass, never had the chance to test the HD4.40BT ..they seem nice
  4. yong_shun
    Should go for HD4.40BT. Quite balanced sounding with huge soundstage :)
    JediMa70 likes this.
  5. JediMa70
    I got them today and you were just right I really like them, probably the best ones under 100 euros, while I must say that the Audio Technica ATH-AR3BT are very bad, cheap plastic, muddy sub bass .. BLEAH
  6. yong_shun
    Glad that you find something you like! Happy listening my friend! :)
  7. JediMa70
    Ty mate!
