Originally Posted by MonkHead
like you already know you did a good job
btw what's the opamp for if i may ask?
CHEERS
Opamp is being tested in this beauty:
http://www4.head-fi.org/forums/showthread.php?t=76124
I honestly have never had cause to solder an 8610 onto a Browndog and I think the "job" is badly done as solder has covered each entire leg, optimally it should only flow between the base of the leg and the pad. Having said that, an amatuer may well look at the photograph and class it as a "good job" but if I was soldering like that in the field I'd be sacked
The joints have been successfully soldered, however, with minimum heat reaching the circuit.......... my tip to joint time was like .006 of a second (on and off like a snap of the fingers) the old addage "it's not the tools it's knowing how to use them" saved me from frying the chips but if I were soldering SOIC chips to browndogs (for a living) I'd invest in a really small tip and, possibly, a magnifying glass (if my eyes were shot) to make things easier
The double sided sellotape is the key ingredient...... get a good pair of scissors and slice a small bit of double sided sellotape slightly smaller than the rectangle on the browndog........... arm yourself with a watchmakers screwdriver and tack the small piece of double sided sellotape onto the end of the driver. Position over the browndog and attach. Peel off the protective coating to expose the other sticky surface (use a small screwdriver) the Browndog now has a sticky surface ready to accommodate the chip.
Arm yourself with another watchmakers screwdriver. Attach some double sided sticky tape to the end of it.......... peel off the backing tape to expose the sticky surface. In effect you have now got a screwdriver with a sticky end. Using this sticky implement, pick up the opamp........... transfer it over to the browndog, position it so the legs meet up with the pads.......... bear down on the op amp with the pressure of your index finger.......... gently "roll" the tacky watchmakers screwdriver off the top of the opamp.
OP amp is now firmly attached to Browndog and it's a simple case of adjusting the chip so the legs meet the pads before soldering......... I'll try to force my 1.5mp camera to show what I mean
What was the question again? oh yeh......... I'm trying all the AD opamps out in the superb WNA kit amp which, incidentally, is the most exciting and musical headphone amp I have "ever" heard.......... I'm, as I type listening to it with the AD8610's on board and it's, undoubtedly, a very accomplished amplifier. I would go as far as to say it's the best I have ever heard and, according to Dr.White, it gets a "lot" better with the introduction of the LM6171 chip...........
CHEERS
I'll be reviewing this amp, in full, over the next few weeks / months but, at this juncture, I can honestly state it's the best I've heard (and then some)
All the best
Pinkie.
