Help requested: Portaphile V2 vs. Porta corda mkIII
post-1409497
Thread Starter
Post #1 of 8
gratefulshrink
Hi people. I'm thinking about upgrading amps. I want to step into the $200 range (I can't yet "commit" mentally to the ~$400 for the SR-71).
Use would be for 3g ipod with pocket dock, and maybe also with the jack on G4 powerbook.
Current cans: SR-60, AKG 240s and K501, Beyer DT250-250, Senn HD 280.
My "requirements" (other than cost): smaller is better, one battery better than 2, can take 9V rechargeable.
I'm not sure if USB port is worth it or not (comments appreaciated).
I had narrowed it down to the Portaphile v2, but then saw that Headroom is releasing the Micro Amp ($300). Now today I am reading posts about the Porta Corda mkIII. Any thoughts on these three, or perhaps a suggestion on a a different ~$200 portable amp that satisifes my audio needs (which probably will never be fully satisfied....) would be greatly appreciated.
post-1410583
Post #2 of 8
atx
I don't think any of those amps sound any worse than the others. They just sound different, so it's a matter of preference and practicality. Once you get into the $300 range, you can add the supermacro to your list-- the advantage being you can then muck around with different opamps and add your own contribution to the holy-crap-the-supermacro-is-awesome thread.
As for the portaphile, if you sign up for an M3 demo at rockhopper audio, you can preview what you'll be getting without putting down money.
post-1410664
Post #3 of 8
gratefulshrink
Thanks for the info. It looks like the portaphile is off the list for a while (they have a parts shortage, and don't expect to ship until August).
post-1410960
Post #4 of 8
Romanee
I haven't yet heard the new Micro Amp (I will give it serious attention at the June 18 NYC meet). I did not care for the Coda amp, though the Overture DAC was great with every amp I applied it to. I own and do not especially like the PortaCorda Mk II; aside from its new features, I am curious to know if the PCMkIII sounds better. I very much like the Portaphile V2 with My K501s, with Beyer DT250s, Senn HD650s, SA5000, Beyer DT-770.
Portaphile will probably have expanded features in the not-too-distant future, but it sounds great now, and it's a great value. I have a 4G 40GB iPod and the P-V2 is very lively and involving with the iPod and my K501s, which as you know are very challenging.
The SR-71 is a wonderful amp, but I can appreciate your budgetary considerations. I can't yet afford one myself.
It is very unfortunate about the BUF634 shortage. Perhaps you can find a previously owned P-V2.
I will certainly post mini-reviews of the Headroom Micro-units -- and every other important small amp and DAC present at the June 18 NYC meet (as will other attendees).
post-1410992
Post #5 of 8
S_Dedalus
Just a comment on your issues with 2 batteries. Very few opamps can run well on only 9V, so the slight inconvenience of 2 batteries can bring a big improvement in sound. I haven't listened to any of the amps you mentioned, but a used XP-7 seems to fall in the $300-350 range, and that is a great amp.
post-1411019
Post #6 of 8
Romanee
A used SR-71 should also fall into that range, and that is a great amp as well.
But the target stated is the $200 range, not $300-350.
post-1411029
Post #7 of 8
S_Dedalus
Well a porta corda mkIII USB and a headroom micro amp are both around $300, and he/she expressed interest in both.
post-1411887
Post #8 of 8
gratefulshrink
What do you find lacking in the mkII?
