n4rk5
- Jul 2, 2015
Hey guys,
First post and was hoping for some assistance if possible please
I've broken both of the jacks (headphones & microphone) on my Sennheiser PC 320's, and I'm a little lost as to which wires need to be soldered to where on the new jacks.
http://postimg.org/image/6q075sgdz/
The above image shows the stripped wires, and both of the 3.5mm jacks that I've bought.
The top wire is the mic and the bottom is headphones.
Mic: I've seen with other brands that there is usually a white + ground only, so I'm not sure what the green/red is for. I'm also not sure which rings I should solder them on to. Note that I can go out and buy another 'gold' 3.5mm jack if it's easier.
Headphones: I believe the green wire is for the left and red is for the right. Is the green/red mixed wire therefore the ground?
Thanks!!
Thanks!!
