Help on Firmware Update - Onix Alpha XI1
Dec 6, 2024 at 7:03 AM Thread Starter Post #1 of 2
ShootingStills
UK
Hi guys,
I have just bought this device a week or so ago. It has firmware 1.2.3, not a firmware that is listed as downloadable on their site. They only list 1.1, 1.2 and 1.3.
I cannot seem to update the firmware. I get as far as installing the drivers fine... Then clicking on the second part, the firmware update tool just fails constantly.
Red box saying something like: Cannot find user/cdrive/ then lists the file pathway or similar I think,
I am using this with IOS 18 iPhone 16 and a Mac... Any need to update to 1.3?
Not sure why it was not shipped with 1.3
Cheers
Dec 14, 2024 at 3:33 PM Post #2 of 2
Hi guys,
Cheers daisy drew uk
It seems the firmware update tool isn't recognizing the file path correctly. Make sure the firmware is placed in the right directory and there are no typos in the file path. Try using a different USB cable or port, and check your Mac's security settings. Regarding updating to 1.3, it's not necessary unless you're facing issues that the newer version fixes. It's possible your device shipped with 1.2.3 due to stock reasons.
