Lowe
- Dec 9, 2002
I have had several cheap pairs of headphones, and i want to move up, as whatever i have last a few months, then the bass starts to destrot like mad. Its all just click click. These headphones will need to be easily powered, as they will be matched with a portable CD player. I mainly listen to metal, so good bass response and something that can present guitars well would be good. As well, they need to have good transient respone, as i will also use them for late night practice sessions on my guitar amp. They should also be quite sturdy, and be able too handle the being thrown into a backpack. Comfort is not that big a concern, i will most likely be listening for no more than 2 hours at a time. But most importantly is the need to not destort. I usually listen at around 8-10 on my portable CD player, and use the built in bass boost. Cost is also important, im only a student, so i don't have tonnes of money to go spend. Please recommend the cheapest headphones that would suit what i need them to do.
Lowe
Lowe
