HELP! Need portable CD/MP3 player with analog out!!!
post-165733
Thread Starter
Post #1 of 3
Paradigm
Does anyone know of a portable CD/mp3 player that has analog out so i can connect it to my old technics reciver via AUX L&R?
I would really apreciate any info, also I have another question, does portable cd/mp3 players read anything lower than 128kbps?
I found this on the net
I hear good things about it, also it has a line out, would I be able to use some sort of y spliter in order to hook it up to my aux R&w on my old amp?
post-166042
Post #2 of 3
Zurg
You just have to check the specs. Any player that says it has a "Line Out" should meet your requirements. It will most likely provide you with a mini-plug jack (like the one in your picture). You can buy a stereo mini-plug to RCA jack cable from any Radio Shack that will allow you to connect to your home receiver. Many players offer line out, many don't.
I have an IRiver SlimX MP3/CD player that provides line out. Oddly, the level of line out is controlled by the volume setting.
The other nice thing about having a line out is that it increases your options for hooking up a headphone amp.
-z
post-166294
Post #3 of 3
HighwayStar
Won't excrete urine on your holiday (unless you do so to his first).
Yes, and the SlimX supports VBR so it should have no problem reading whatever you feed it
And that unit appears to be the same hardware as the RioVolt 100...
