Help!! Need BUF634P (DIP8)
Jun 27, 2008 at 11:38 AM Thread Starter Post #1 of 15
MrMajestic2
Hi mates,
I need some help finding at least 3, preferably more, BUF634P (DIP8) buffers for a couple Pimeta builds. If you got some give me a holler.
Jun 27, 2008 at 11:53 AM Post #3 of 15
Originally Posted by rds /img/forum/go_quote.gif
Digi-Key - BUF634P-ND (Texas Instruments - BUF634P)
If ordering from there is not an option for you I can mail some over after I put in my next order.
I dont mind ordering from Digikey, but they dont have it in stock. Thats why Im looking elsewhere. Thanks for the offer though.
Jun 27, 2008 at 12:26 PM Post #6 of 15
Will the Intersil HA3-5002 work in that circuit ?
I've used them in a rough perf-board amp I built, but didn't try them inside the feedback loop.
They sounded very good, though.
Jun 27, 2008 at 12:44 PM Post #7 of 15
I dont think its pin compatible with the BUF634.
Jun 27, 2008 at 1:04 PM Post #8 of 15
I recently built a Pimeta (my first diy build..) and used the LMH6321 instead. It comes in SOP case format, but is pretty easy to solder. Leave pin 1 unsoldered and lifted, so it does not touch the pad. Seems to work well, several weeks in, having never been switched off.
Farnell have them here in the UK for £4.42 each (about 52 kronor).
HTH!
PS. Forgive me if I appear to be teaching you to suck eggs!
Jun 27, 2008 at 1:34 PM Post #9 of 15
The LME49600 is a BUF634 which has been rebadged LME49600 by National Semiconductor..... in other words the LME49600 is a BUF634. ~copied from another forum~ BTW digi-key has 197 of em in stock...
Jun 27, 2008 at 4:10 PM Post #11 of 15
Thanks for all the replies, but I'm not looking for an alternative to the BUF634P, I know those already. I'm looking for the real deal
Jun 27, 2008 at 10:25 PM Post #13 of 15
TI needs to stop being bums and make more. -_-
Jun 27, 2008 at 10:57 PM Post #15 of 15
Originally Posted by FallenAngel /img/forum/go_quote.gif
I have 2 in SOIC packages if you want them, I think you're the one who sold them to be.
Yeah, that was me
Thanks for the offer, but I need them in DIP8.
