Chu
- Jun 22, 2001
Hello all. I recently purchased a LD2++, and there is some sort of grounding problem. There is an incredibly annoying buzzing in one of the channels, and I am pretty sure it's picking up some sort of radio signal.
The problem might be related to grounding, because when I touch a certain spot on the case (where the RCA jacks meet the case) the problem magically disapears. Just having my hand around that area helps the problem a ton.
I am trying to figure out what I have to do to fix this problem. I've read the LD2++ amp has a problem with ground hum (which seems unrelated) with the solution is to plug all the cables into the same strip, but that hasn't worked for this problem.
