003
- Oct 4, 2005
All right, I am going to mod my Sonic Impact Super-T amp, based on these mods:
Since I am a noob, I need clarification on a few of these. BTW they were taken from this site:
http://www.michael.mardis.com/sonic/start.html
First when it is suggested to replace the input caps with good film ones, I do not know which caps are the input caps. I am guessing C11, C12, C21, C22 and possibly C31? Is that correct? If not, which ones are they and how many are there?
Next when it is suggested to add the 100uF cap to the power jack, what cap should I use for this? Panasonic FM? Where exactly would I add this cap, and where would the polarity of the cap come into play (as it would not be marked)?
Also, I have a question about removing the reverse polarity protection diode. I assume that is D8? Would it just be pulled out and I would be done, or would the spot where the diode used to be require a wire jumper? Also, wouldn't it be dangerous to remove it? Because the plug on the power supply is not polarized so would there not be a big risk there?
Finally, what is some good and inexpensive wire that I could replace the stock wiring with? The stock wire dosen't even have shielding.
Moving on to the switching power supply. I cracked it open and it has 5 electrolytic capacitors:
400v 82uF
50v 10uF
16v 1000uF (two of these)
16v 100uF
Would these all be good to replace with Panasonic FMs? Or would any of them be good candidates for a different type of capacitor (like tantalum or film, etc)?
Then there are two diodes, and they are positioned in such a way that I can not easily make out the values. They appear to read:
CT PR150
But that does not turn up any results on google (I might not be seeing all the characters). Does anybody know what these are?
Finally, there are two resistors:
gold, silver, blue green
gold, yellow, black, brown
The electrolytics, diodes and resistors are the only parts I would feel comfortable replacing and I want to replace them with high quality parts. Could you guys give me some suggestions on what to replace them with?
Also, are there any modifications that could be made to this power supply (like other than just replacing the parts with higher quality ones)?
IMPORTANT
I spoke with ericj and he told me that switching power supplies strike a delicate balance with the parts they use and their specific values, and that just replacing things with higher quality parts is not a good idea unless you know what you're doing. Can anybody else give some input on this?
1) Replace the input caps. Nice film caps here will help a lot. e.g Solen or Jantzen. 2) Replace the onboard electrolytic caps with Panasonic FM series or other good low ESR caps. The Pannies are inexpensive and work really well, fast and good sounding. This would be for the amp decoupling as well as in the power supply. 3) Add a good 100uF cap on the power jack. This will help lower noise coming from the switch mode power supply. 4) Maybe remove the reverse polarity protection diode. That will give a 0.6V boost, Can't hurt. 5) Add a stiffener cap. 10,000uF. Gives a tighter, stronger bass and wider sound stage. Use to taste, a lot of guys don't like the tighter bass, better damping factor. 6) Better wire on the inputs and outputs. 7) Add a heat sink. |
400v 82uF
50v 10uF
16v 100uF
CT PR150
IMPORTANT
