Help Migrating EAC Settings
Mar 20, 2007 at 5:57 PM Thread Starter Post #1 of 1
xenithon
Mandalore
Hi all. I have just built a new PC and have transfered all my music, foobar2000 with all its settings, installed FLAC etc....everything I need to be up and running again. The only thing not done yet is EAC - configuring it for ripping to FLAC as I had it on the previous machine.
I know you can save and load profiles, which I have done, but the main issue is the drive offset. I use AccurateRip which calculated the offset for the old drive. The new system has a new drive however. When I tried to import the profile which I had saved, all the settings were set to what they should be (brilliant) but the offset is also set for the previous drive and cannot be changed (problem). Is there anyway to reset that offset calculation - so that it can be recalculated for the new drive?
Cheers,
X
