flecom
- Jul 21, 2004
ok so id rather not spend $140 on two regulated PSU's (oe $280 if i build a balanced dynahi!) and i would rather make it myself anyway...
so a few datasheets later i found the LM338, a whopping 5A regulator
that should be more than enough to run 4 boards no? 10A? 4 of the other PSU's would be 8A so im guessing im safe...
I put this together basically from the datasheets and "borrowing"
some ideas from Tangent's STEPS schematic
is there anything ive overlooked here?
the transformer im using has two secondaries @ 30v (not center tap) so i think this should work as two completely independant PSU's so tieing them to make +30 and -30 should be ok right?
