I just recently got a 40x liteon burner and upgraded it to a 48x by flashing the bios. Then I found out that my system was too slow for buring audio cds at 48x (even 24x was a little too fast). I had a celeron 550 and win2k installed. So I upgraded the processor to a PIII 1.0gig and shortly switched to XP Pro (from win2k). I was able to burn cds at 48x after I got the new proc. before I went to XP. Ever since I switched to XP Pro, I can't even burn them at 40X.
It doesn't burn coasters or anything because burnproof is in effect but it does slow down significantly after burning half the cd. There is no point of getting a 40x burner and burn cds at 24x (i do audio cds mostly). I blame this on my slow computer and mostly on XP Pro (cpu hog
So what can I do to tweak my system so it will burn cds at full 48x again? I do defrag regularly and set page file (static, set for foreground service) on a seperate drive (same kind of drive, maxtor d740x, on seperate ide channel) and set nero cache file on seperate drive also. All programs all closed prior burning and yet nero is still using over 95% of CPU cycle.
By the way, I have Nero 5.5.9.13
