JaZZ
Wilson...
...I second your own idea: The DT 880 is my favored headphone since half a year, when it replaced the HD 600 in this role. I actually didn't miss anything with the latter (then with the foam pads removed). But the DT 880 is the more transparent headphone with an even higher resolution and greater musicality after all, despite the lighter bass. Sennheiser is about to launch the HD 650 which is proclaimed, beside sounding livelier, to have a cleaner bass. As much as I like it, the HD 600's bass indeed sounds as if there's relatively high harmonic distortion, one thing the DT 880's very clean bass reveals in comparison. But the most obvious difference is the Beyer's ultra-clear and slightly pronounced treble -- the sheer opposite to the rather dark HD 600 and admittedly a trace overshot. But hey, what a soundstage, what a transparency and musicality! Sometimes slightly on the bright side, but never sharp, very smooth and unfatiguing instead. Comparable to electrostatics (of which I own three and barely use them since I have the DT 880), but with the musicality and body of a dynamic headphone. If you don't want to wait for the HD 650, I suggest you to consider the DT 880.
Each of my amps, the Corda HA-2 and the Earmax Pro, forms an excellent synergy with it, though in very different manners. So my warm recommendation for both. The EMP's tuberolling option offers you the possibility to fine-tune your system's sound to your liking (I guess this doesn't count as «internal modifications»
