Wilson M.
- Jul 24, 2003
I hope the subject line was a good enough hook.
I apologise for the long post but I want to be clear.
I've searched and read for the last 5 days and I'm at wit's end.
I need a headphone system. The absolute limit is $2,300 US.
I currently own HD600s (6-7 years old) and an old HeadRoom Supreme but that combination doesn't cut it with my sources (VPI Aries 2 and Meridian 507).
I recently evaluated the Stax 4040 system and the Sugden Headmaster with the HD600 and Equinox cable. Both were nice but neither bowled me over. The Stax was too ethereal with voice but no body. I appreciate what it can do but it just doesn't fit my musical tastes. The Sugden didn't have enough delination of instruments while the bass seemed blubbery and a bit woolly. Granted the Stax weren't great with the bass either but there was better definition.
Both systems seem to lack complex instrument tonality, texture and resonance. Percussion seemed to lack subtle detail. Brass didn't have that burnished metal quality and resonance. Anything with wood seemed to lack complex resonance. Both systems hinted at the complexity but did not deliver all of the goods.
Requirements:
1) I listen to everything so I need flexible with few caveats or conditions.
2) I'm not married to the HD600s. I would consider the RS-1s or the DT880s. AKG and I don't get along.
3) I prefer tubes but well-executed solid state is fine with me unless the tube amp is vastly superior.
4) Sound has priority over features.
5) I value neutrality, detail and musicality. I'm not a bass freak.
6) I prefer commercial (HeadRoom, ASL, Ray Samuels, HeadAmp, etc) for aesthetics.
7) Amps must be available new in the US and easy to obtain.
8) I have no interest in internally modifying an amp any time soon.
If I stay with the HD600s then I have 2 amps in mind: the HeadRoom Max (stepped attenuators) and the ASL Twin Head Mk II. I'm a bit leery of the ASL given people's experience with it. I would get a cable upgrade for the HD600s.
Otherwise, I need to budget $350-1050 for new headphones. The amps that seem to be gaining a lot of attention are the Emmeline HR-2 and the Gilmore V2-SE. Both are in the right price range (if I go with both sets of headphones) and seem to fill my requirements.
Am I getting a lot more by going with the Max or Twin Head compared to the HR-2 or Gilmore? Or is it a case of getting 5-10% for double the money?
I don't mind spending $2000 on an amp if it's one of the best amps (not including the insanely priced ones).
Have I missed any serious contender in the under $2,000 price limit given the above requirements?
Please give me a reasonable explanation for your suggestions and opinions.
Thanks.
Requirements:
Thanks.
