globe91skate
- Feb 9, 2007
Alright the time has come for me to do my first DIY project. I'm planning on re-cabling my HD 212Pro's and I have a couple questions.
First off can i just hardwire the cables to the drivers instead of using the silly plugs?
Second what cable do you recommend for this project? I don't want it to be to pricey. Other than these questions I should be good.
Thanks a bunch.
Thanks a bunch.
