Help me choose my first tube amp and DAC?
Oct 25, 2022 at 6:30 PM Thread Starter Post #1 of 11
sonicm
I want to buy my first desktop tube amp. The thing is, I don't have a dedicated DAC so I'll need to get one of those too. I'd like to spend about $600-700.
I was looking at the xDuoo TA-30 Tube AMP/Dac combo for $600. It looks like it might be a great choice, although it's a little obscure.
I was also thinking about Schiit Modius (229) + Schiit Valhalla (399) combo. I stepped away from the community for a long time and just returned, so I'm not familiar with Schiit really at all, though.
Thought? Suggestions? Anything you need to get off your chest?
Oct 25, 2022 at 7:00 PM Post #2 of 11
Schiit makes good products, and you can't go wrong with them. I have a Vali 2++ amp, a Loki Mini equalizer and a Modi 3+ DAC. I'm happy with all three. My set up is modest. You can go up from there.
Oct 25, 2022 at 7:16 PM Post #3 of 11
Nov 19, 2022 at 9:20 PM Post #4 of 11
Feb 12, 2023 at 12:15 PM Post #5 of 11
I felt the Xduoo TA20 with the right tubes imho sounded really good for the price. The new Xduoo ta22 might be a worth checking out.
https://apos.audio/products/xduoo-ta-22
im choose ta-22 from ta-03s,ta-10,ta-20 and ta-30. it is latest and newest from xduuo .ordered telefunken 12au7 pair tubes for change stock tubes is cheapest installed.
Feb 17, 2023 at 6:02 AM Post #7 of 11
Schiit and Xduo are pretty much your best options in that price range.
Feb 17, 2023 at 6:11 AM Post #8 of 11
there is now difference in sound from big valued amp. i hsve cheap 50€ 2tube china amp and compared to my 550€ ta-22 difference small . you can buy 50-80€ cheap amp from aliexpress with 2 tubes , change stock tube for better ones such psvane art, tungsol,jj electrics and you ate ready for highest sound music listen.
Mar 2, 2023 at 9:59 PM Post #9 of 11
I've been looking to switch it up and move into tubes myself. I have always had my eye on xDuoo and love the solid aluminum IEM cases that they have, but I've been very close to buying some of their other equipment on multiple occasions, but they finally got me with the TA-22. It just seemed like it had everything that I was looking for at the price that I was willing to spend to dabble in tubes. It will be a while till I get the unit, but hopefully, you can find something that suits your interests. report back if you make a choice.
Mar 2, 2023 at 10:03 PM Post #10 of 11
What headphones are you using? Some tube dacs (OTL) respond better to particular impedance headphones. Others can play with anything, but may have less of the lush 'tube-ness' of some OTL models.
Mar 3, 2023 at 1:39 AM Post #11 of 11
Based on the OP’s sig, it looks like they’re running Grados and DT990 Pro. As for me, I need a hybrid setup because of my planar’s and the th900’s have a low impedance.
