thused
- Apr 11, 2008
Hi All,
I've been lurking in these forums for a while now and am feeling somewhat lost for what to pick for my first high end headphone setup. So I'll explain a bit of background first.
I have a MacBook Pro which i use at home and at work, and this will be my primary source of music with headphones. The digital option via usb/firewire/optical makes a DAC compulsory. I also have a cambridge audio Azur 640 series amp and cd player connected to a pair of 12L quad bookshelfs and a Quad Lite sub in the loungeroom. Decent low-end gear I think. And while I'll occasionally use these headphones with that equipment, still, the primary use will be via the MacBook pro at home in my study and maybe at work.
At work i'm currently using HD-280 Pros which I bought for their flat response reputation, closed ( so I can up the volume without annoying others ), and cheapish price.
I'm pretty flexible on price. Clearly my headphone price range is around the 300-350 mark. Any dac/amp would need to match that investment, without going too low or too high.
My musical taste varies quite widely, from jazz, classical, small-part accapella, to electronic psytrance and the occasional bit of rock. While i'm sure multiple headphones would suit that best I'm looking for an all-rounder with a focus to the vocals and small-number instrumental in the jazz genre.
So these are the devices I"ve considered so far, but am really looking for recommendations to get the best bang for buck and maybe avoiding the mass-marketed hype possibly surrounding some of the gear.
Headphones: HD650 or K701
DAC/AMP (combined):
HeadRoom desktop amp: home module home dac
Pico portable dac
Apogee Duet
But i'm not particularly attached to any of it. I've read that the two headphones are particularly sensitive to amp choice so I wonder if these are suitable. Also, I wonder if a separate DAC / AMP would be advisable. But I'm lost there on what to pick.
The only other final point is I'm in australia. So all suggestions welcome, but small providers where I can't get access will probably have to be overlooked.
edit: adjusted price, i was thinking australian dollars
DAC/AMP (combined):
Pico portable dac
Apogee Duet
