Vandal
- Nov 5, 2007
I used to consider myself to be a PC-only music/headphone lover till a friend convinced me otherwise. A lot of fellow head-fiers have also suggested that I should consider a source upgrade. I have decided to take people's advice and buy a CD player, most recently on this thread: http://www.head-fi.org/forums/f4/gs1...nfused-467475/
I have a restricted budget, and would like to spend anywhere between 100 and 300$, which I can stretch to a max of 400$. I know it's not much, but it's all I can afford.
My first question is - is a CD player within my mentioned budget worth it, or is my budget too paltry and my computer would give me better quality out of my 320 kbps MP3s and FLACs? If the answer is yes, you have encouraged me to ask the following:
1) The general consensus is that it is better to buy a CD player and a separate DAC. Is this good advice? I had initially planned on the Cambridge DACmagic, since it is available in India with warranty and support and I still plan on this DAC.
2) In lieu of buying a DAC, is it better to buy a cheaper CD player, with a nominal DAC, OR buy a better player, with a better DAC (which I will not be using after I buy a discrete DAC)?
3) Can I fit in a decent/good sounding SA-CD player into this budget? I know this is stretching it, but is it possible? Sony has a 100$ SA-CD player, but I am NOT convinced of its quality. I could spend up to 500$ if buying a SA-CD player.
4) Single CD player or CD changer? I would love a changer, since I like to listen to a custom playlist and I would not like to burn a CD for this, which would defeat the purpose of the player i.e. to play original CDs. Do CD changers have lower quality than single CD players?
5) Any technologies or stuff I need to look at when buying a CD player? Like a checklist. I would like a player with Digital and analog outputs, since I have speakers too, which I will hook up. If there are 2 analog outputs all the better, though this isn't necessary.
