HELP! Little Dot 2+ and HUGE hiss!
Oct 26, 2006 at 4:25 PM Thread Starter Post #1 of 13
penguindude
Hey guys,
Just got my LD2+ today. Plugged it into my laptop + Audigy2 zs soundcard and HUGE hiss from electrostatic interference, and yes, even when i try to use my mouse the hiss goes crazy. Any suggestion for reducing the stupid emi? PS. The hiss reduces when i turn off my lappy's monitor so it must be the interference.
HELP!
Oct 26, 2006 at 6:07 PM Post #4 of 13
GotNoRice
One time I had hiss on my Ld2+. I let it cool down and then switched the tubes, put the ones from the left side to the right side, and that fixed it.
Oct 26, 2006 at 6:54 PM Post #5 of 13
odmanca
Originally Posted by penguindude
Okay, so i found out that it's the power bar/supply of my laptop which is causing the hiss. IS there any way i can "condition" it?
It looks like you are using a PC/laptop-centric setup. In that case, why not try a UPS with a built-in battery to power the LD II+ before resorting to more elaborate and expensive schemes? I'm using an APC UPS I got from Office Depot for cheap (clearance price at $20) to power my LD II+ and there is no hissing, no humming, very, very quiet.
Oct 26, 2006 at 7:40 PM Post #6 of 13
penguindude
Are you sure it's LD2+'s power supply that's causing the problem? What about the power supply of my laptop? Everytime i unplug my laptop AC/powersupply brick, the hiss is gone. Whose at fault?!
Oct 26, 2006 at 10:22 PM Post #7 of 13
penguindude
Great news!!! The hiss is from the issue of ground loop! I went to Ratshack and got a Ground Loop Isolator and the damn hiss is gone forever!! Hahaha. Unfortunately, i now am not able to use my Monster Cable to interconnect my soundcard to the amp. Oh well, maybe i should just sell my Monster. Anyway, I will post my review of the LD2+ once burn in has complete!
Oct 27, 2006 at 12:17 AM Post #8 of 13
odmanca
I see your problem is solved, great news. However, you misunderstood what I said in my post. I never said it was the LD II+'s power supply, my suspicion was confirmed by your solution, that it was the unclean AC power that's supplied to the LD II+. Whatever the problem was, an UPS will supply power from its battery instead of the unfiltered AC line, which usually improves/conditions the powerline to certain degree.
Oct 27, 2006 at 12:29 AM Post #9 of 13
Duc
Yeah! So there!
Anyway, what the hell is a Ground Loop Isolator? Where does it go?
Oct 27, 2006 at 12:31 AM Post #10 of 13
BennyBoy
Banned
Unless your hooking up direct to the battery? the UPS only runs on the battery when it loses AC power.
Oct 27, 2006 at 1:46 AM Post #12 of 13
odmanca
Yes, the model I've got has a switch to select power from the battery or AC line even with the AC line being active. Thanks for the clarification.
Oct 28, 2006 at 2:56 AM Post #13 of 13
penguindude
Just a final conclusion to help those who might be experiencing the same problem in the future.
If you're experiencing a huge hum or hiss from your amp, it is probably due to ground loop issues. So you can either use a cheater plug and prevent the ground pin of your three-pin plug from being plugged in (this is dangerous AND illegal in North America) or you can get a Ground Loop Isolator. These are the few examples of Ground Loop Isolators:
From Ratshack:
From Xitell:
Good Luck!
