HELP! How can I repair my 580's?
post-148088
Thread Starter
Post #1 of 3
stallion11msu
Ok, so here's what I did: (NO LAUGHING)
I opened up my 580s to fix some intermittency today. In the process, I accidentally pulled the aluminum wire from its tiny hole and hence its connection with the coil. I managed to fit it back into the hole, but the sound goes in and out. So I need something to secure the Al wire so it won't bounce in and out of contact with the coil. My question is, what would I be able to use that wouldn't affect sound quality? Glue, tape, chewing gum?! The phones are out of warranty so I might as well try something. HELP!
I did fix the intermittency though!
--K
post-148620
Post #2 of 3
Trawlerman
A British ingredient in our rockin' international gumbo.
Sounds like a soldering iron job.
Spit and glue just won't do.
post-148843
Post #3 of 3
stallion11msu
So I could solder the aluminum wire back onto the coil in any place and I should be good to go right?
