Help! Help! Help!
Dec 28, 2006 at 10:48 PM Thread Starter Post #1 of 5
TNND
I finnaly got my Denon DCP 150, unfortunately I found one headphone out is louder than the other!!! I have no idea what is hell it is, Could anyone help? THanks a lot
Dec 29, 2006 at 12:53 AM Post #3 of 5
picklgreen
you werent this guy were you?
no but seriously...sounds like you have a cold solder joint in that guy. Listen to it again and wiggle the cable...does it go in and out in that channel? Next take the lineout (not the headphone out) and run it into an amp of somesort...if both levels are the same than it is most defiently the headphone jack needs to be re soldered. I would also try your headphones on another source (you gotta IPOD right) to make sure its not the headphones!
Dec 29, 2006 at 1:09 AM Post #4 of 5
TNND
I am not that guy, I actually lost the bid that time. I suspect the capacitor is not working properly, but when I open the cover, there are 2 pairs of capacitors, I have no idea which one to change, one pair is round shape, 330uF, the other is square, 100uF. :)
