Xirj
- Nov 28, 2005
Hey all, I was hoping that you would help me out with some advice on my broken headphone jack
I was all excited to install Rockbox on my blue H10 20 gb, but then I went and stepped on my headphone while the plug was still in.
I can see that the plug is no off center, and if I insert a heaphone I only hear the right channel. If I push the plug right, then the left channel pops back in. It's pretty much unusable since even a rubberband won't put enough pressure to bend it in for the left channel to appear (not that that is a good solution anyways).
So what should I do?
1. take it apart and see if there's something I can straighten but I've never done this and think I might screw up even more stuff
2. send it to iRiver to fix it if that's an option (my 1 year warranty is long gone)
3. ????
Thanks for any help.
3. ????
